Old 07-10-2016, 03:33 PM   #41
Blackhat6mike's Avatar
Send a message via Skype™ to Blackhat6mike
Originally Posted by spock123 View Post
A TPMS is piece of mind.
X2
I watch my TST507 monitor more often than my speedometer since I'm generally on cruise control. I can't imagine doing without it. Why someone would go without a TPMS is beyond me. My insurance provider asked me if I had a system before he quoted me a premium on my coverage. Don't know if I saved any money, but it showed him I was a concerned owner. I'm sure that a lot of claims are due to "tire failure" damage.
2013 Silverado 2500 HD Duramax/Allison Tuned
Aviator Wright Flyer #1919
"First In, Last Out". 11B4Y
DAV, MOPH, VFW, 5/7 Cav,1/8 Cav Assoc.
11th ABN Pathfinder Co. N7MIP
Blackhat6mike is offline   Reply With Quote
Old 07-10-2016, 03:40 PM   #42
Originally Posted by Eskimo57 View Post
We had a blowout on Monday (4th of July). Tire pressure was checked before we left, tires have less than 5000 miles on them, it was hot out, 97 degrees.
Are those Tredit T03 rims? If so look them over carefully for micro cracks. I have seen about 6 or 7 of these that have had them and are early signs of rim failure.
jtaylor1920 is offline   Reply With Quote
Old 07-10-2016, 03:58 PM   #43
I run within 1 or 2 degrees of max sidewall pressure every morning regardless of the ambient temperature whether it is 25 degrees in the am or 90 degrees or anywhere in between.
Old 07-10-2016, 04:21 PM   #44
My G614 I start them out at 105 and the truck tires I start the out at 4 pounds under that I have them set at. Front truck tires 57, back truck tires 76. Watching my TST 507 it doesn't take but a few minutes to get them up where they are supposed to be. Front tires 60 rear tires 80, trailer tires 110. I look at my 507 more than DW, just don't tell her.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 07-13-2016, 10:00 AM   #45
Commercial Member
Your Cold inflation pressure (60 / 80 ) is what you set the pressure to before any movement or exposure to the sun.
You should NOT be setting tires lower than what they are "supposed" to be.
I write a blog on RV tire application and safety. RVTireSafety.NET
Note the new address .NET Please copy & paste the URL the forum has problems with the direct link
Also give seminars on tires at RV events across the US. 40 years experience as tire design & quality engineer for major tire mfg. Freelander 23QB on Chevy chassis is my RV
Tireman9 is offline   Reply With Quote
Old 07-13-2016, 02:27 PM   #46
It doesn't take but a few minutes to get them to what they are supposed to be and higher. I don't see the problem.
Old 07-13-2016, 04:19 PM   #47
Commercial Member
Tires are designed to support the load based on the cold inflation and at the higher inflation that occurs once the tire is running. While your pressure number may increase to the psi needed to support the static load you are actually under-inflated when running.
Now it is not likely that being 3 to 5 psi low, even when hot, is going to cause an immediate failure but there will still be more damage done to the tire structure in the long run. All damage to a tire structure is cumulative and non-reversible so you are pushing the limit as you approach end of life use.
You didn't say how long you normally run your tires but unless you change very early i.e. a couple of years, there is always the possibility that you may have a tire that fails just before your planned replacement date. At that point you would probably just claim the tire was defective and forget the fact that you chose to operate the tire in a constant low inflation level.
Just wanted you to be aware thet you are not following proper inflation guidelines. Your decision though. As long as you are willing to accept the consequences.
Old 07-13-2016, 04:50 PM   #48
I still can't see the problem, my front tires go to 66 lbs and the rear tires go to 86 lbs or more. The trailer tires go to 116 or more. Some people on here don't run the Goodyears G614 at 100 lbs. I don't think a tire knows when it's hot or cold air pressure
Old 07-13-2016, 05:33 PM   #49
Commercial Member
Well as long as you are comfortable with relying on your background of decades of tire design and testing I guess you can continue your practice.
Old 07-13-2016, 07:09 PM   #50
It just seems dumb to me, my tires get to the right lbs in less than five minutes. I'm sure that if you look on this site you would see where other people are running the same tires as mine at different lbs and having no problems.
