Check all caulked seams (roof, sides etc) and windows, door frame etc. Redo any areas that are cracked or lifting.
Check the date on the tires and replace if they look wore out or more than 6 years old.
Have the battery load tested.
Repack wheel bearings and check brakes and that the break away switch is operative.
Check if anode rod in water heater is still OK.
Sanitize the fresh water system.
2007 Surveyor SV230 - 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
