Old 05-12-2016, 08:07 PM   #61
crunchman12001's Avatar
Originally Posted by Iwritecode View Post
Are the blocks in the bottom right corner of that picture under the stabilizers? That could be part of it. Put the blocks directly on the frame right next to them and take the stabilizers out of the equation completely.
X2
2015 F-250 FX4
Old 05-13-2016, 05:45 AM   #62
MilCop4523's Avatar
Originally Posted by Ecook View Post
Do you mean all the way around the slide?
the photo is worth a thousand words... it looks likes its well supported.
shouldn't sink or settle much.
and personally i cant see where there would be much weight resting on the tires and rims.
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
MilCop4523 is offline   Reply With Quote
Old 05-13-2016, 07:30 AM   #63
Dodge Guy's Avatar
Originally Posted by MilCop4523 View Post
then again why does the slide out manufacturer recommend pulling them in for storage as seen in my earlier post?
sitting on a lot waiting for mom and pop to purchase is no different than me or you storing it for the off season...
The reason is so that you don't sag out the springs on one side of the trailer.
I would never use slide out supports, even if set up permanent on blocks. The reason is when the trailer settles the lighter weight of the slides will not settle the same amount and will put the slide out in a bind that may damage or break it. Slide outs are designed to be self supporting, so adding supports can be damaging. Imagine if a tire went flat with a slide out support in use. Even stabilizing jacks will still let it drop.
Bottom line, Don't Use Them!!! If they were required the manuf would supply them.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
slide, slide out
