05-02-2016, 06:25 PM
#21
I would like someone from Forest River to sound in on this one
Sandy and Steve
Chooie, Baby, Grizzly, Sophie the 4 fur babies
2018 Rockwood 8301WS fiver
2003 Ford F-250 super duty diesel
Vinemont, AL
05-02-2016, 08:53 PM
#22
I'm wondering if the recommendation sheet being spoken of was from Forest River or from the dealer which from the post my guess is CW. I believe when I got a camper from CW I got a sheet of recommendations to purchase as well. If that is the case as a dealership of that type it is my opinion they do not care so much about what is correct or what the manufacturer suggests as much as they try to up sell as much as they can because that is where the huge profits margins are.
Eastlake, Ohio
2013 F-350 Turbo Diesel
2016 Heritage Glen 368rlbh
05-02-2016, 09:34 PM
#23
Always Learning
The owners manual isn't good enough?
There are less and less reps on here. Sadly, they seem to get beaten up and go quiet after a while (or leave FR and no one back fills them).
05-03-2016, 05:22 AM
#24
Yes, the stabilizers work. Like I said, you don't attach them under the slide itself, they support the main body frame under the slideout. Since I have been using these I get almost no movement.
Good luck.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
05-03-2016, 09:28 PM
#25
Originally Posted by MilCop4523
Slide outs and the use of the supports AKA stabilizers or that Forest River urges the use of them?
my 2012 Salem 27RKSS came with a sheet which had several recommendations - one was the use of stabilizers (some people call them slide out supports) for underneath the slide out (some people call them Tip outs.)
Camping World...
Reference that FR recommends the use of slide out supports. Could be for specific units. I only asked because I had always heard not to use them. I emailed Steve from Coachmen and stated that they were not necessary.
2016 Coachmen Freedom Express Liberty Edition 292BHDS
05-10-2016, 06:52 PM
#26
Do you guys think it would help if I let some air out of the tires? It is blocked up on four spots along the frame. If I let air out the the frame would be on those blocks. I'm just not sure if what I'm feeling is from the movement of the tires.
05-11-2016, 03:10 AM
#27
Insert witty title here
The owner's manual for my TT says nothing about putting supports under the slides.
Sent from my iPad using Tapatalk
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
05-11-2016, 12:08 PM
#28
Trust us - its not the tires... its the 1000 + pound slide out sitting on 2 small steel rails and another 400 to 1000 lbs that's sitting in the slide out when you have it extended.
slide out supports were invented to take care of that "Bounce"
just go with the flow and order the supports (several types have been identified. and then let us know how you made out.
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
05-11-2016, 12:13 PM
#29
and my service guy for my new truck said my spark plugs for my 2013 F150 Ecoboost were good for 60,000 miles too but last week at 40,000 miles they had to replace all 6 plus the coil packs as well under warranty.
just because a sales person says they are not needed or necessary...well if they can get a larger repair later on from you at your expense they will. Some trailer shops will also tell you that you don't need to wash and seal your roof 2 times a year as well.
trial and error - but there is a ton of knowledge on this site who have learned by their own error by not spending a few minutes and listening to others errors and fixes.
also use something like the X chalk between your tires in addition to the stabilizers. beats bent rails and not having to be able to close the slide out back into transport mode because something is bent..
05-11-2016, 12:25 PM
#30
LIMPERT slide outs...
Mechanical Maintenance
Although the system is designed to be almost maintenance free, actuate
the room once or twice a month to keep the seals and internal moving
parts lubricated.
Check for any visible signs of external damage after and before
movement of the travel trailer.
NOTE: For long-term storage: It is recommend that the room be closed
there is no difference between you putting the trailer into storage and leaving it sit in a summer fall park for 5 months of the year unsupported other than you and the Mrs. plus friends and family are sitting in the slide out.
That 1000 lb + slide out is still overhanging the main frame work for support.
so if the manufacturer says to support it AKA close the slide out back into the unit for long terms... it is logical that the same would hold for supporting it in an extended position.
http://www.primetimerv.com/download/...tionManual.pdf
bottom of page 4.
05-11-2016, 12:44 PM
#31
slide out supports do not take care of bounce . using them could cause damage to the slide out mechanism . if you put supports under the slide out and the rest of the unit moves you will put great stress on the slide out.
the bounce comes from sitting on springs and tires . there are tt and fiver supports to prevent bounce . jt strong arms for one . if you have good jacks for extra support you can eleminate most if not all bounce . most tt jacks are just stabilizers not designed to support the weight of the tt so adding extra jacks will take the weight off the springs and tires reducing bounce . slide out supports are a no no and will cause damage
05-11-2016, 01:01 PM
#32
That is a gigantic leap in logic. Keeping the slide closed while in storage and using slideout supports are not even close to the same thing.
I stand by my (and many other's) advice to never use them.
05-11-2016, 01:11 PM
#33
As for the OP, I'm on a permanent site and have been for 5+ years.
My current trailer has 4 separate slides. I've blocked it up using cinder blocks and wood shims underneath the frame only. I have blocks on each of the four corners as well as in front and back of both tires for a total of 8. This along with the JT strong arms that came with the trailer have made it pretty solid. Even with 2 adults, 3 kids and 2 dogs I never feel it bounce.
I still have yet to see documented evidence of any manufacturer suggesting the use of slide-out stabilizers.
I run my slides out in the spring and bring them back in the fall. I'd guess 99% of other permanents do the same thing. Never heard of anyone having a problem doing that.
05-11-2016, 08:26 PM
#34
I have basically the same set up as you except the JT Strong Arms and we still get a good amount of movement. I don't feel it when I'm standing in the trailer. Only when sitting on the couch or in bed.
05-12-2016, 07:04 AM
#35
found a Keystone reference (SOB trailer company) reference
KEYSTONE RV COMPANY OWNER'S MANUAL: page 17, Leveling & Slide-Outs: "In extended situations, it is advisable to add support blocks under the slide-out room. Do not raise the room. Just touch the bottom."
Although it states blocks... the key word is "SUPPORT"
I'll use my supports under teh slide outs as well as the factory support jacks under the corners as it actually works to the level of "SUPPORT" that I need it to. It takes teh bounce out which is what someone asked how to accomplish that task.
if the product was not intended for use then millions of campers dollars are being spend on products made by a few companies like UltraFab sold by dozens of companies like E-Trailer and Camping World and Amazon EBay which do not fulfill that promise. why do they sell so many and why is there never a peep about these being fraudulent products?
05-12-2016, 07:32 AM
#36
MilCop4523, it's your trailer and therefore you can do as you please with it. When you happen to have a tire or tires go flat with the slide(s) supported, you will no doubt have major slide out damage.
My take on it is if the mfg wanted the slides supported, they would furnish the supports. JMHO.
Have fun and do whatever you want.
05-12-2016, 07:52 AM
#37
Eastlake, Ohio
Nail on the Head! Youroo!!
05-12-2016, 08:22 AM
#38
thats correct and the great thing everyone has an opinion. the OP asked for opinions/ thoughts on the matter aka advice. they can sift through them and flatten the tires to let air out which they believe is causing the bounce.
million dollar industry in creating a product not recommended by some... makes sense not to use them for some as well.
sort of like Bras some work taking the bounce out and offer support for a few but not all.
05-12-2016, 08:33 AM
#39
Do you have a link for that? Because I'm not seeing it in the one I found.
http://www.keystonerv.com/media/3003...17_revised.pdf
05-12-2016, 08:43 AM
#40
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
