Old 06-11-2015, 09:28 AM   #1
mikejm
Brake light out
I have a Columbus 320RS by Palomino and the LED brake light is already out. I don't want to pay Camping World $130 to change out the lighting unit, is there a way to fix it myself? Appreciate any input.
Mike JM
mikejm is offline   Reply With Quote
Old 06-11-2015, 09:59 AM   #2
TURBS's Avatar
Led lights normally don't just "go out" I think you may have another issue.
But it's "possible"
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
Old 06-11-2015, 10:01 AM   #3
Have all the lights gone out, brake and running? If yes I would say you lost the ground to the unit.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 06-11-2015, 10:26 AM   #4
Check your 7 pin connector first. Mine seems to oxidize all the time so some light doesn't work. Just clean the connectors on the trailer and see if that works.
camperman275 is offline   Reply With Quote
Old 06-11-2015, 10:28 AM   #5
TURBS's Avatar
If it's only one light then the 7 pin wouldn't be the issue.
TURBS
2011 32bhok Sabre
Old 06-11-2015, 10:38 AM   #6
TURBS
2011 32bhok Sabre
True. I wasn't clear that it was only one light and it's an easy thing to check and fix before spending the money.
Old 06-11-2015, 10:44 AM   #7
TURBS's Avatar
No doubt!
No idea is a bad idea!
Unless of course it costs "me" money!
TURBS
2011 32bhok Sabre
Old 06-11-2015, 10:58 AM   #8
mikejm
It is just the brake light that is out. Is there a fix other than replacing entire light unit?
Old 06-11-2015, 10:59 AM   #9
TURBS's Avatar
If it's actually the led circuit board, no.
As asked earlier do the tailights work?
"normally" individual leds will start to go out but usually never all of them at once.
I'm leaning toward a wiring issue.
TURBS
2011 32bhok Sabre
Old 06-11-2015, 11:03 AM   #10
mikejm
Just the brake light is out.
light, brakes
