Old 09-19-2014, 07:35 AM   #1
Brakes
I have 2005 Cherokee 28A+. I need to replace the brakes on it. I know you can buy whole kits to remove from the trailer and bolt back on. Does anyone know what the size of it is? I also have the right front wheel seems to be wearing on the inside. I am suspecting it is due to the axle or the mount being bent. My brakes are worn down and need to be replaced and I was thinking if I bought the whole kit and could adjust the wheel from there. Thank you for your feedback.
ljlund3872 is offline   Reply With Quote
Old 09-19-2014, 07:47 AM   #2
mud yapster's Avatar
They are usually 10" or 12" and electric or hydraulic brakes. Just pull your tire and hub off and look at them. There is usually a part number stamped on them also.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
brakes
