Old 09-15-2011, 12:17 PM   #1
chromeOkie's Avatar
building dump station
Sorry in advance if this has been covered, but couldn't find it. I am wanting to build a permanent dump station at my farm so we can camp by the pond for extended trips. Any suggestions on a DIY project?
2011 F150 Ecoboost FX2 Screw 6.5 bed
2012 FR Tracer 230FBS
chromeOkie is offline   Reply With Quote
Old 09-15-2011, 01:14 PM   #2
Do you want to do it legal?
Sent you a private message
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 09-15-2011, 07:56 PM   #3
chromeOkie's Avatar
lol, legal is never an issue, but chemicals near my pond worry me a bit.
Old 09-15-2011, 09:49 PM   #4
You can buy a small septic tank, and put in your own drainfield, with a small backhoe or a bobcat, and some dirt. If you properly maintain it, you should not have any problems with your septic tank or pond. It really is a pretty simple procedure. I have a septic tank that I have been using for 28 years. Don't drive on the drainfield, and have the tank pumped out about every 5 years, depending on usage. Randy
Old 09-18-2011, 09:50 AM   #5
Check out the attached link. It should work fine with occasional camping. How to Construct a Small Septic System - wikiHow
jamesp is offline   Reply With Quote
Old 09-18-2011, 10:17 AM   #6
RV Newbie
buzzards27's Avatar
All sorts of warnings should go off before you consider using these plans. One, I doubt if it is legal in most jurisdictions. If ANY of your ground water flows onto a neighboring property and you bootleg one of these you could be in a lot of trouble.
Do it legally, get a perk test and apply for a permit, doing so protects you and your neighbors.
2005 FR Lexington 210 6.0L 8500 miles
2007 2500 Silverado Ext. Cab, 6.5' bed 5.7L
2010 Ford Fusion Hybrid
1963 Ford 861 5 speed with loader
1958 Ford 800 Select-O-Speed (parts tractor)
buzzards27 is offline   Reply With Quote
