Old 11-04-2013, 03:06 PM   #1
gmcnitt's Avatar
Building RV Garage Finally
Hello, Well three break ins later, tv units both stolen, broken locks and glass, the bedspread taken and the sleep number remote (who can explain these thugs..?) we are building a garage at home for our 2009 Charleston 40' pusher. Here are the pictures after just 3 days of framing, these guys are fast! Will be running 50 amps out when they are done, no plans to insulate or get crazy yet, may do it later on once the TX heat starts hitting.
ID:	42278   Click image for larger version
ID:	42279   Click image for larger version
gmcnitt is offline   Reply With Quote
Old 11-04-2013, 03:32 PM   #2
Old car's Avatar
Very nice. I have a 30 X 50 barn but I built it before I ever had a trailer. Just two feet higher and I would have an enclosed storgage area. Live and learn. Size does matter!
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
Old car is offline   Reply With Quote
Old 11-04-2013, 03:34 PM   #3
Get out the Skilsaw, hammer & nails and get to work with the mod!
Old 11-04-2013, 03:43 PM   #4
Timex's Avatar
Looks great! What are the dimensions? Are you going to put a roll up door on the front? I highly encourage you to insulate walls and ceiling. It is fairly cheap and you won't have to worry so much about winterizing or frozen pipes! You won't regret it.
Timex is offline   Reply With Quote
Old 11-04-2013, 03:56 PM   #5
Ford Idaho's Avatar
I would do the ceiling at least, Lowes has the stuff for a DIY blown in insulation job.
Old 11-04-2013, 03:57 PM   #6
gmcnitt's Avatar
Its 25 X 45. Yes, it will be a roll up door on the front. I will insulate it I am sure, as I did freeze the ice maker valve last year.
Old 11-04-2013, 04:09 PM   #7
Timex's Avatar
What part of TX? I'm in south MS and it will freeze lines if left outside in the winter. But I don't worry anymore since I have my building!
Old 11-04-2013, 04:24 PM   #8
gmcnitt's Avatar
Fort Worth......typically not a freeze problem here, but it does happen!
Old 11-04-2013, 04:30 PM   #9
B47
Yeah - occasionally it does and if you don't believe it,just try to buy a water spigot freeze cover at Lowes or Home Depot when the Weathermen predicts freezing temperatures here
Old 11-04-2013, 04:32 PM   #10
Brother Les's Avatar
Rule #1. think of how big a garage you will need and then.....
X2.
Built a 30X40 for the truck and car.......
Now no room for either...... but I do have a fridge in the corner with beer.
Brother Les
