Old 08-10-2015, 12:24 PM   #1
cabinets coming apart
we have a 2012 Salem 22 foot travel trailer an we are noticing the cabinet doors are coming apart at the corners, has anyone else had the problem an why. this trailer is kept under cover an my wife an I are the only ones that use it.
Thank You
ronngail1 is offline   Reply With Quote
Old 08-11-2015, 01:17 PM   #2
I've had a few come apart on our fifth wheel. We have the gooseneck adapter on the unit and it locks down on the ball in the bed of the truck. So whenever a bump, rough road or the stress that's put on the camper when towing it jolts things loose and apart sometimes inside the rv. I'm just going to have to go with a different hitch system
OKI Marine is offline   Reply With Quote
Old 08-11-2015, 01:33 PM   #3
You will need to re-glue them. Use wood glue and either large rubber bands till they set up, or buy some cheap adjustable clamps from china freight.
The interiors of RV's go through extreme temperature, humidity changes that are much greater, than what your cabinets at home would experience.
Old 08-11-2015, 02:09 PM   #4
if you have a small air compressor, you can get a little nail gun. or even a Nail Gun Compressor combo for about $99. Then carry a box of 1" finishing nails with you to tack everything they failed to tack properly...... or you can get finishing wood screws and use a screw gun.
Corpus Christi, Texas
TT: 2016 40' Chaparral 360IBL at 14000lbs
TV: 2016 F450 Platinum 6.7 CC LWB FX4, B&W Companion Hitch
IronCobra is offline   Reply With Quote
Old 08-20-2015, 09:28 AM   #5
I have a 2016 - same issue. I bought a 2 pack of Irwin mini clamps at wal-mart for $7, and a tube of Gorilla Glue for $4. Came out perfect and for $11 you can fix every cabinet if you had to. Pain in the A** but the least of the problems I've had with my FR.
BigPatCal is offline   Reply With Quote
