Old 04-16-2014, 05:40 PM   #1
Cable antenna came with cascade fishhouse
How does the cable antenna work omnidirectional hooked it up to tv pushed auto search and got nothing put up one of those flat antennas in window hit auto search and picked up 5 stations is it me or the antenna.
gellis1 is offline   Reply With Quote
Old 04-16-2014, 06:10 PM   #2
Did you push the button to turn on the booster amp first?
Gaffer222 is offline   Reply With Quote
Old 04-16-2014, 06:42 PM   #3
I am really new to this didn't know there was a booster button. Wheres that located and thanks in advance.
Old 04-16-2014, 06:48 PM   #4
Should be on the wall plate for the main coax outlet. A small light should come on when it's pushed. It's a very small button. Sometimes there is also and 12 cigarette lighter type outlet on the same wall plate. Turn on for antenna and turn off when connected to cable tv. Once it's turned on, try the channel scan again. Let us know if you get it to work.
May look like this.
Old 04-16-2014, 07:00 PM   #5
Ok thanks like I said it's all new to me
Old 04-17-2014, 07:14 PM   #6
So... how many channels did you get with the booster on compared to the other antenna?
Old 04-17-2014, 08:18 PM   #7
I am storing it about 20 miles from my house and being in northern MN its kind of between seasons not enough ice and still to much snow and cold but am going over Saturday to work on a few other projects I'll let you know how it turns out
Old 04-19-2014, 11:03 AM   #8
Gaffer222 yup there's a little button on antenna hookup for booster, black button on black cover hard to see worked great as soon as I pressed it thanks for the info. Happy Camping!
antenna
