Old 03-13-2010, 09:42 PM   #1
kre
Cable Television Question
I have a Georgetown 350TSSE.
I have hooked up to the park cable television, but I simply cannot figure out how to get cable stations on my Olevia TV.
Don't see anything in any manuals I have. Can someone help me with this?
kre is offline   Reply With Quote
Old 03-13-2010, 09:53 PM   #2
dharri770's Avatar
Cable connections are notorious for being loose from the factory from what I have read on this forum. Pull the plate off of where you connected the TV and check the connection on the back side. I had to do this on my trailer and found every connection VERY loose.
2002 Ford Excursion w/ 7.3 TD, 3.73 rear
2008 Salem 26TBSS
Wife and (3 kids): 10g, 9g, 4b
dharri770 is offline   Reply With Quote
Old 03-14-2010, 12:28 AM   #3
CLASS "A" Senior Member
cfsoistman's Avatar
Is the input selector pushed in for the front TV for cable? Did you try going into the menu on the TV from the remote. Set the input from antenna to cable and then do a channel search. Does it work on the other TV?
Hopefully you don't have the same situation as I had with mine. My Park Cable as well as the cable from the selector to the rear TV would not carry a signal through. Not sure if they were borken off or cut but I ran new cables myself and solved the problem.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 03-14-2010, 06:44 AM   #4
cardinal4fun's Avatar
As said above make sure all the connections are tight, go behind the wall plate to get at them. Second is you ant. power boost OFF you will not get cable with it on. When all else fails start with a direct connection to the t.v. once you have a good cable connection with that you can move on to the other connections you have.
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
cardinal4fun is offline   Reply With Quote
