Old 10-03-2014, 01:39 PM   #1
Cable TV - Satellite TV Jacks
Have a 2014 Flagstaff 5th wheel and have a question that the dealer cannot answer. Between the CABLE TV F-connector and the SATELLITE IN F-connector on the rear/side of the trailer is a small female mini-jack. What is the purpose of this mini-jack? Here are the links to the photos.
https://www.dropbox.com/s/f9eirda2pm...0571a.JPG?dl=0
https://www.dropbox.com/s/yz0y1cdfqt...0573a.JPG?dl=0
ID:	64049   Click image for larger version
MartyQ is offline   Reply With Quote
Old 10-03-2014, 04:19 PM   #2
BooBoo23's Avatar
Looks like an audio jack. Is there anything on the inside wall outlets that may match it? I tried to Google wall plates but didn't find anything. Is there a manufacturers name or model # on the plate that is visible to do a search with.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
BooBoo23 is offline   Reply With Quote
Old 10-06-2014, 11:49 PM   #3
There is nothing in the 5th wheel near the entertainment center or elsewhere. Guess I am going to have to remove the outlet and see if anything is connected to the jack, if no one else can give me a hint.
Old 10-07-2014, 01:47 AM   #4
My guess... external antenna earphone jack. Possibly cellphone booster repeater. If your floorplan has a desk area I would look around there for another jack.
rana is offline   Reply With Quote
Old 10-07-2014, 05:41 AM   #5
Look behind it probably find it in the back of a cabinet and trace the wire. May be nothing.
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 10-07-2014, 06:45 AM   #6
mark0224's Avatar
x2
most likely nothing, I have a satellite radio antenna on my roof but its not hooked to anything and I don't have a sat radio. They put things in anticipating an option to make it easier after things are all together.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 10-07-2014, 06:56 AM   #7
I wonder if it's a 12v source for something
Old 10-07-2014, 10:58 AM   #8
Scootdawg's Avatar
I have a 2015 8289WS and on mine is the exact same hole between the satellite and cable jack. Now I am wondering what it is also.
Scootdawg is offline   Reply With Quote
Old 10-09-2014, 04:26 PM   #9
Called my dealer today and asked this question. Waiting on a reply. Going to take the screws out to see if it is connected to anything. Will keep you updated.
psrujak is offline   Reply With Quote
Old 10-09-2014, 04:32 PM   #10
Scootdawg's Avatar
I use to have direct tv and I wonder if the cable for the satellite has a little plug on it for power and that is what the jack (or hole) is for?
jacks, satellite
