Old 11-19-2015, 10:40 AM   #1
Camper Leveling
I have a 2016 Model 831RLBSS with two slide outs on the drivers side. I'm relatively new to campers but my question is: do you level the camper side to side before or after you extend the slide outs?
PCStrope is offline   Reply With Quote
Old 11-19-2015, 10:49 AM   #2
I believe most people level before extending the slides simply because it's easier to leave the trailer hooked up to your vehicle to get blocks/levelers under the wheels.
Just level it so the side with the slides is slightly higher. It will probably sink a little once the slides are out.
Iwritecode is offline   Reply With Quote
Old 11-19-2015, 10:51 AM   #3
Pickin' & Campin'
It'a always a good idea to get your unit as level as possible before extending the slides.
A level RV will improve any frame flex/twist that may transmit to the slide mechanisms making them bind.
That said, some people with just two slides on the same side find they need to have the slide side of the rig just slightly higher (before extending) as the added weight/leverage of the extended slides will then bring the unit back level for camping.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 11-19-2015, 10:51 AM   #4
panthercity's Avatar
We do it before so that they are torqued as they go out. Once the TT is leveled, and the four corner stabilizers are down, the sides shouldn't affect the level.
Certified JB Welder. Certified 3M Duct Tape installer.
Certified Farmer's Co-Op bailing wire expert. Graduate of the "Rock on the side of the Trail as a Hammer" school of motorcycle repair.
Getting old is just a matter of narrowly missing all the things that kill you.
panthercity is offline   Reply With Quote
Old 11-19-2015, 11:05 AM   #5
I've honestly never found that to be the case. In my experience, the slides always pull the trailer down a little bit.
Especially if you are parked in grass.
Old 11-19-2015, 11:09 AM   #6
Fulltime family RVer
How would you level it once the slides are out?
Old 11-19-2015, 11:10 AM   #7
AquaMan's Avatar
I concur. Always parked mine about a 1/4 bubble high on the side with the most or biggest slides.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 11-19-2015, 11:14 AM   #8
I dont know what type unit you have or suspension type! I know on Rockwood/Flagstaff units with rubber ride and 2 slides on 1 side just level and deploying the Stabilizers will NOT be level! Youroo!!
Old 11-19-2015, 11:17 AM   #9
Jim34RL's Avatar
What does your owners manual say. I know on all three of my former trailers that I have had stated to keep the slides in and then level. With my new Cedar Creek we level the camper with the auto leveling system. The slides must remain in since the camper is moving up and down to achieve a level trailer.
Keep the slides in this is easier on your trailer frame.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 112K+miles
Old 11-19-2015, 11:19 AM   #10
The OP is New to this Level Game,after a few trys they will know how much Shim to use BEFORE they deploy the Slides! Youroo!!
camper, leveling
