Old 02-15-2014, 08:05 AM   #21
MtnGuy's Avatar
We seldom stay at campsites with sewer hookups, but when we do I pour a little IPA (rubbing alcohol, isopropyl alcohol) over the water faucet outlet, and carefully take a candle lighter to it. When the flame goes out, I run the water to the ground for a minute or 2, and then again wipe down with Listerine before hooking up.
Old 02-15-2014, 08:15 AM   #22
Kaadk's Avatar
Originally Posted by MtnGuy View Post
We seldom stay at campsites with sewer hookups, but when we do I pour a little IPA over the water faucet outlet, and carefully take a candle lighter to it. When the flame goes out, I run the water to the ground for a minute or 2, and then again wipe down with Listerine before hooking up.
I'm not going to waste a perfectly good Alexander Keith's on the faucet. But I am thinking I'll need to have some kind of disinfectant from now on.
The surest way to lose is to play Marco Polo with a ventriloquist.
Kaadk is online now   Reply With Quote
Old 02-15-2014, 08:22 AM   #23
LKicklight's Avatar
Nasties
You want to talk about NASTY and Inconsiderate, let me tell you about our LAST and I do mean Last KOA Stay. Went to the shower one morning, early mind you as DW had not climbed out of bed yet, did not want to wake her, anyway I got in the shower and low and behold, guess what was just lying there on the shower stall floor, you guess it, a Big Ole Chocolate Tootsie Roll, well you know what I mean, how gross was that!
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 02-15-2014, 08:28 AM   #24
Kaadk's Avatar
I've only seen that in a State Park. Never at the KOA's. The private campgrounds are usually better at getting the restrooms cleaned.
Old 02-15-2014, 08:31 AM   #25
davel1971's Avatar
when on a full hookup site, I always hold my gray water on the last night/morning. Use that to flush the hose after dumping black.
David & Lynn
Old 02-15-2014, 08:34 AM   #26
Ford Idaho's Avatar
As do I, I use the black tank flush system a couple of times or till clear water runs.
Old 02-15-2014, 08:39 AM   #27
MtnGuy's Avatar
High alcohol content rubbing alcohol ( IPA, Isopropyl Alcohol), not Indian Pale Ale.
I will change my last post to reflect that.
Old 02-15-2014, 08:54 AM   #28
I don't think the Campground owner(Public or Privite) would think very much of campers setting FIRE to their Water Hydrants! Youroo!! What would Smokey Bear do?
Old 02-15-2014, 09:00 AM   #29
Taranwanderer's Avatar
This is why water is your friend when dumping...I always fill my black, grey, and galley tanks to full before dumping, dump, then refill all three, and dump again. Maybe I'm a little OCD about it, but this way, there are never any "nasties" left to worry about. Just let the black hose drain, hang it over the spare tire to dry, and stow. Good to go. The drinking water faucet is never in the equation.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 02-15-2014, 09:06 AM   #30
LKicklight's Avatar
Cleaning Black Hose
Same procedure on our end, dump the black water first thing, then run the gray water through, while still plugged in the ground, I run hot water and Green Stuff through the hose as well, wash the outside off the same way: Clean and smells great, Like having that Hot Water Connection right there:
camper
