Old 09-13-2006, 08:09 AM   #1
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
Question Campground Transportation Question
Hi All,
I tow with a 2006 F250 supercab with a 6 1/2 foot box. I would like to buy a golf car to take along for transportation in campgrounds. Alas, even the shortest standard golf car that I have found on the net exceeds the length of my pickup bed. I guess I could buy electric scooters for the wife and myself, but I would much rather have a two person vehicle so we can ride more safely and together. Can anyone share their knowledge of a campground-acceptable vehicle that might suit my needs or, perhaps, of a workaround for my problem? No, I really don't want to trade the truck, and towing with the tailgate down would severely hamper my turning radius.
dimurrrw is offline   Reply With Quote
Old 09-13-2006, 07:00 PM   #2
milzat's Avatar
dimurrrw,
Here's something to consider.
I have a friend who camps with us and he carries his Golf Cart in his short bed pick-up while towing his TT.
He made a short tailgate using angle iron and expanded metal to fit his truck. He made it just long enough to extend past the bed to support the rear wheels of the Golf Cart. It doesn't look too bad and does not interfere with the tongue jack when turning and backing. I think it is only about 1' or so long.
milzat is offline   Reply With Quote
Old 09-15-2006, 04:50 AM   #3
AKA Bluebird
dimurrrw's Avatar
Michael,
Thanks for the reply. It does seem that what you suggest would be the most practical alternative. The only other thing I can think of is to pay an arm and a leg to have a golf cart modified by cutting a foot out of the middle - assuming that would even be doable.
Old 09-15-2006, 11:22 AM   #4
milzat's Avatar
Michael,
I picked up a golf cart from a friend in hopes of doing the same thing.
I removed the body panels, took measurements, did some serious thinking, then gave up on the project for this spring.
With the batteries, controller and switches in the rear having to be relocated(nowhere to go). And, the steering, brake, and throttle up front needing to be relocated also, once you remove enough material to get it to fit in the bed, there is no room to place your feet.
Maybe I'll take another look at things this winter.
Old 09-17-2006, 03:56 PM   #5
Mrs. Bear's Avatar
This is a utility vechicle. Maybe this would work, though I'm not sure how long a golf cart is. It doesn't have to be a Polaris, that's just what we like.
*Bear says that not all campgrounds allow quads.
RANGER XP (4x4 700 EFI) ENGINE :
Engine Type: Polaris Twin Cylinder
Displacement: 683 cc
Coolant Capacity: Liquid - 3.25 qt / 3 ltr
Carburetion: Electronic Fuel Injection (EFI)
Drive: Switch-engaged on-demand true 4-wheel shaft drive
Drivetrain
Transmission: Automatic PVT
Dimensions/Capacities
Length/Width/Height: 113x60x75in / 287x152.4x190.5cm
Dry Weight: 1185 lbs / 537 kgs
Box Capacity: 1000 lbs / 454 kgs
Ground Clearance Front - 11in/28cm / Rear - 12in/30.5cm
Load Capacity
Hitch Towing Capacity: 1750 lbs / 794 kgs
Mrs. Bear is offline   Reply With Quote
Old 09-17-2006, 06:42 PM   #6
milzat's Avatar
Most all campgrounds I've been to only allow electric golf carts or electric scooters.
NO gas engines.
Old 09-17-2006, 08:10 PM   #7
MRimmer's Avatar
NO gas engines.
Same around here but I am looking for that used golf cart deal gas or electric.
MRimmer is offline   Reply With Quote
Old 12-13-2006, 06:54 PM   #8
Golf Cart
Hi All,
Hi Richard
Can you tell me how long the golf cart is if its only a few inches you need might have an idea.
JG
James Gibbons is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
A question on slides revetch Rockwood 3 10-22-2006 10:45 AM
Battery question Kman General Motorhome Discussion 2 10-04-2006 09:53 AM
Campground Reviews dimurrrw General Community Discussions 7 09-26-2006 02:03 PM
Question FancyFree General Community Discussions 8 08-29-2006 10:17 AM
Photo Gallery Question Gear Jammer Forum Admin, News and Member Account Info 1 08-26-2006 12:20 PM
