Just thinking out loud, without using water and cooking, and with some heat inside, your shouldn't have a problem like windows icing inside. Unless your camper is sealed up like a tupperware bowl, the outside relative humidity in that cold of weather (10 degrees F) should balance things out every time you open the door...
Let us know how it goes
Success is hiring someone to mow your lawn so you can play golf for exercise.
2018 GMC 2500 Duramax Denali
2018 Coachman Freedom Express 287BHDS
