Old 01-03-2012, 09:49 PM   #1
Flagstaff 625D Popup
Can a slider be retracted if it is raining ?
We currently have a pop-up (625D) and we don't like that if it is raining we need to re-open the camper at home for it to dry out.
We'd like to trade up to a travel trailer, but I was wondering if the slides have the same problem ? If you slide them in when it is raining, do you need to open them again to dry out ?
Thanks, Bean
bean is offline   Reply With Quote
Old 01-03-2012, 09:54 PM   #2
jtstromsburg's Avatar
No expert here, but I have brought my tt slide in, in the rain. I just quick wiped it down with a towel. But I guess that would depend on if you can get around the slide when it's retracted?
Joel
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is online now   Reply With Quote
Old 01-03-2012, 10:12 PM   #3
Fire Instructor's Avatar
Not a problem at all. That's one of the reasons why we got away from the HTT and went to a TT with a slide.
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 01-03-2012, 10:49 PM   #4
Herk7769's Avatar
The slide seals are like giant windshield wipers and squeegee most of the water off as it retracts.
HAM CALLSIGN - KC3FFW
Old 01-04-2012, 12:52 AM   #5
bikendan's Avatar
and if it has a slide topper, even less water to worry about.
ours does and we don't even have to wipe the top of the slide off. nearly all the water runs off the topper as it rolls up.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 01-07-2012, 09:06 AM   #6
MPI_Mallard's Avatar
Don't worry about it!
07' Dodge 3500 Diesel Dually/6.7L Bully-Chipped / 68RFE six-speed/Jake Brake
07' Cedar Creek 37CDTSD Daydreamer fiver'
Mallard @ Frau BlŁcher
MPI_Mallard is offline   Reply With Quote
Old 01-07-2012, 10:24 AM   #7
Anacortesians
Provided the blade seals along the top of the aperture the slide retracts through aren't distorted, the "wiper" effect Lou describes will keep the water out. We had the LR slide seal partly rolled over and didn't see the problem because of the topper. A strong wind had pushed the rainwater under it.
We've since sprayed the roof of aech of the slides with moly dry-lube. We did the same to the bottom seals also, though they're more for keeping small critters out. It doesn't rain upwards very often.
Frank and Eileen
No longer RVers or FR owners
Old 01-07-2012, 01:23 PM   #8
2000 Cardinal 5th Wheel
If it is raining hard when I have to slide in, I leave my Ceiling blade-fan on for a minute or two after ............ .it dries it right off!!!!
bfast54 is offline   Reply With Quote
Old 01-07-2012, 06:36 PM   #9
2Susan's Avatar
The top and the sides of the slide are accessible from the inside of the camper. You might need a step stool. I use a microfiber mop head to dry off the top, wipe down the sides. It is the same thing I use on the floors - seems to do a better job with sand than a broom. You could wrap a towel around your broom to get into the corners as well
2Susan is offline   Reply With Quote
