Old 08-04-2016, 08:18 AM   #21
Witch Doctor's Avatar
As in walls and dinette, unless you found it outside, do you have a sleeper where you found it? Or a recliner?
Sent from my SM-N920V using Tapatalk
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 08-04-2016, 08:26 AM   #22
WolfWhistle's Avatar
Originally Posted by Bama Rambler View Post
It looks like a rivet that never got peened. Most likely a dropsy from the assembly line.
Rivet? I thought they only used chewing gum or nothing at all?
Hang on to it, one day in a galaxy far, far away, it will be revealed.
WW
XLR Hyperlite 29HFS
Ram 2500 6.7L CTD
Triumph Thunderbird
A Modder's work is never done!
Old 08-04-2016, 08:46 AM   #23
Originally Posted by rwatson908 View Post
The rivets are pulling apart where the base of the Murphy bed attaches to the frame...No other issues noted with the rest of the TT.
rwatson, like you and dchapman, I too have a 21DS. Mine also has the murphy bed. Would you please take a moment and post a picture of the problematic rivets in the murphy bed? I'd like to inspect mine and a picture of yours would help greatly. And like you, I've had only minor problems with my unit...and those I have fixed myself.
Thanks!
2016 Microlite 21DS
2014 Ram 1500 QC 6 cyl. 8 spd.
Blue Ox SwayPro
windsurfdog is offline   Reply With Quote
Old 08-04-2016, 09:03 AM   #24
Part of the IED that goes off 30 days after the warranty expires. All RV's have them.
Rockwoodjoe is offline   Reply With Quote
Old 08-04-2016, 10:33 AM   #25
dmchapman's Avatar
It is small...described as a nap couch. Folds flat to accomodate the Murphy Bed. If this is a rivet it seems way too large to be part of the framing of the coach. About the size of the pivots for the right side if the couch. The item is smooth and unmarked. No evidence of a 'misfire' if from a riveting machine.
dmchapman is offline   Reply With Quote
Old 08-04-2016, 10:42 AM   #26
dmchapman's Avatar
Thanks!
I don't see anything with rivets regarding my Murphy Bed. It appears to be a wooden structure with a piano hinge and 2 gas struts.
Old 08-04-2016, 01:09 PM   #27
That's what I remember from mine. Hopefully rwatson will be able to post a pic so we can see what his looks like.
2016 Microlite 21DS
Blue Ox SwayPro
Old 08-04-2016, 03:26 PM   #28
That is a pivot point goes between two points and acts as a joint which moves look around the sofa there are more which haven't fallen out yet LOL
cfo111 is offline   Reply With Quote
Old 08-08-2016, 04:38 PM   #29
dmchapman's Avatar
It is part of the drawer slider. I was able to pop it back into place. Supposed to keep it closed but no better with it in than when it was popped out. Doesn't affect the overall use of the drawer and it would be far too much work to replace the sliders because they are pop-riveted to the drawer and metal mounting brackets. Thanks for all of your entertaining guesses and comments. 😜
2015 Microlite 21 DS
2012 Silverado extended cab Z71
Old 10-03-2016, 07:55 PM   #30
Orion's Avatar
Thanks!
Include me in 21ds owners. I suspected that piano hinge might become an issue and will be watching it.
Sent from my iPad 18 using Forest River Forums
2017 Flagstaff FLT21DS
2011 Tundra Platinum, 5.7l, 2WD, Firestone bags...
Orion is offline   Reply With Quote
