Old 10-22-2010, 06:16 PM   #51
Herk7769's Avatar
He is home with a cold, but here is his response.
"There is a vent to the roof of the rv. However, filling the tank with the valve closed allows the water pressure to build up enough so the additional pressure of the water in the drain spout is enough to burst the tank. When the tanks are made, the top of the tank is thinner than the bottom. It could be that the tanks top was too thin to handle the pressure. Fortunately for me I had already flushed the tank enough times that there was no sludge only smelly water in the rv's bottom. I still leave the valve closed and dump several gallons of water in the toilet to allow for a good gush of water to flow.
I'm not sure if I'm leaving on Sunday. Not feeling well with a cold!
Sent via DROID on Verizon Wireless"
From his response, it sounds like he had the bottom valve closed to fill up the tank quickly. I don't think he mentioned that little tid bit when he told me his tale of woe the first time.
HAM CALLSIGN - KC3FFW
Old 10-22-2010, 08:37 PM   #52
Boy it make you think about the open road & wave action for the top. What will that do to the top if 8lb & open hose pressure made it blow it top. Hope this is just a bad tank.
2010 wildcat 31ts
05 Ford F350 SD PS
camprat is offline   Reply With Quote
Old 10-23-2010, 06:36 AM   #53
jimh's Avatar
Originally Posted by camprat View Post
Herk I don't doubt what you say & it is always good to keep a eye on things. Was he using a blow out bag that seal off on the vent pipe to clear it & pressure it up? A 10 foot of 1 1/2 sch 40 holds 1.06 gal = about 8.3357 pounds
the vertical weight of the water is abt 1 lb/30" reguardless of the volumn.
jimh is offline   Reply With Quote
Old 10-23-2010, 06:39 AM   #54
jimh's Avatar
Originally Posted by herk7769 View Post
I passed the request for the 3 pack set along to the DW for Christmas. Sounds like the install will be a spring project when we get back from Florida.
I did not want to recommend them until I tried them myself. I will, of course, photo document the project.
if u get them and install them, let me know what u go thru. i have a set but found that i needed to drill another set of holes (origionals are bonded in on mine). i have a close quarter drill but the sewer line makes that too tight. need to know how u get the sewer line out of the way.
Old 10-23-2010, 10:58 AM   #55
Herk7769's Avatar
You don't seriously mean that as stated right?
I think I misunderstood what you meant by your comment.
Are you talking about pounds per square inch of footprint?
Pounds per square millimeter?
As stated you could be implying that a 30 inch deep swimming pool has the same weight of water as a 30 inch tall 1 inch pipe.
Old 10-23-2010, 11:05 AM   #56
Herk7769's Avatar
Jim are they glued in or is the rubber grommet compressed by the cap nut. From the video it seems the rubber sleeve around the sensor is compressed by the first nut to seal the hole and the wire is held in place by the second nut.
Once you unscrew both nuts you should be able to wiggle the sensor out of the 3/8th inch hole. I was under the impression the "bonded in" ones were on the fresh water tank sensors.
If indeed you will need to drill new holes, it would seem that you are free to mount them where ever you want and what ever spacing you want.
As long as you know where they are you will know how full your tank is.
You could make "full" actually BE full. Etc.
I guess if push comes to shove you could cut the black pipe and use a rubber connecting sleeve (or sleeves) to join the cut section(s) together.
Old 10-23-2010, 12:01 PM   #57
Herk7769's Avatar
Burst tank follow up
I wanted to confirm he was filling his tank with the valve closed and here is his reply:
"Yes, that is the only way I can add water to the tank to flush it. The spray just doesn't work as well. A massive flow of water is needed to really flush the tank well. My only problem was that I forgot that I was filling it until the tank burst. With the overhead vent to the tank, air will not buildup in the tank only water. I'm surprised I didn't see it gushing out of the overhead vent. I believe that the additional pressure created by the 10" vent filling with water before it would gush out would have created the additional pressure to cause the tank to burst. As mentioned earlier, it could have been that the tank was not up to standards when installed in the rv."
I can only assume he meant that trying to push a column of water out the top with water pressure from the hose in the tank was what burst the tank. Not sure what he meant by {10" vent} either. I assume he meant 1 inch. Remember that the hose would have been in the vent pipe too.
Old 10-23-2010, 01:23 PM   #58
jimh's Avatar
I meant psig pressure. A 10' stand pipe would exert abt 4 psig at the btm. Dia wouldnt make a diff n pressure
Old 10-23-2010, 01:56 PM   #59
Herk7769's Avatar
Ah, I agree totally. In a static environment I see your point.
In the context of my friends mishap, I think the water hose at the bottom trying to push all that water out of the top raised the pressure inside the tank to well over the PSI coming in from the water hose. A weak spot in the tank designed for static (weight of liquid only) pressures (weights) could have had its break point exceeded.
Old 10-23-2010, 01:59 PM   #60
jimh's Avatar
It looks like the probe was screwed in w the threads glued. I can't move them
