Old 11-12-2014, 09:46 AM   #1
carbon monoxide detector
I have a 2013 Rockwood Mini Lite and have a question regarding the Carbon monoxide detector. Every time we use the shower for the first time after unit has been sitting the detector goes into alarm mode. Last night while using compressed air to blow out the water lines had the same issue. There were no appliances turned on and the gas was shut off at the tank and has been for 2 months. It appears to be a gas that is formed in the water lines that causes the detector to go into alarm mode. Has any one else had the same problem?
cdconine is offline   Reply With Quote
Old 11-12-2014, 10:29 AM   #2
Witch Doctor's Avatar
Some monitors are very sensitive to odors. If you had your unit go off blowing air in it just smelled something different, did you use an oil compressor? Also some will go off if it is to close to the door when you open it. Also if you been sitting and use the shower odors from your bath area til it used and cleared out from the bath area. IMO I don't think you have problem with it. Hope that helps you.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
