Old 10-06-2014, 10:31 AM   #1
Carefree Add a Room
After some research I discovered that the Dometic patty o'room can not be used with an automatic awning. The Carefree can be used. Since our camper is now 'stored' and not accessable to me, do you know if there is a fuse that could be pulled out that only affects the power awning? Also, do you perceive a problem to have one side of the awning lower and tied down so that it does not change position. Thank you. DW wants a screen tent outside the camper for our seasonal camping in 2015.
wiscoheel is offline   Reply With Quote
roo
