Old 04-25-2016, 12:50 PM   #1
Question Caulk Problem
I'm a new owner of a 2008 Lexington GTS Class C with a caulk problem. The caulk, on the latch side, around the door is coming loose from the side panel. I believe the cause is from the door swinging outward, and it's causing the jam to flex. Of course the three paint color scheme is affected. Also, on the back cap, the caulk is coming loose in the joint. Has anyone had a similar problem, and how can I repair this?
Peteski
Peteski is offline   Reply With Quote
caulk
