08-14-2015, 06:17 PM
CB radio antenna help needed
I want to install a CB in my new Forester Class C (Chevy 4500 chassis). I've got the radio picked out but I'm having issues trying to figured out what to do for the antenna. I've got Velvac mirrors so I was going to attach an antenna mount as far outboard as possible on the Velvac arm. Only problem with that is that a 4' antenna doesn't reach to the roof edge and a 5' antenna extends about an inch past the roof edge. From everything I've been able to learn about CB antennas, 2/3rd of the antenna is supposed to be above the roofline.
I don't want to drill any holes in the coach so that's a non-starter for a solution.
I'm a retired LEO and I had a couple assigned vehicles that had antennas mounted on a bracket on the front fender that went under the hood and attached to the inside of the fender. I'm thinking this may be my only option. I can install a 4' or 5' antenna so it's forward of the nose of the coach body overhang. I figure radio coverage towards the rear of the vehicle is going to be slim to none, but as the entire length of the antenna is exposed across the entire vehicle front, I should have reasonable transmission/reception coverage in front of me.
My question for the CB experts out there is this - do I need a No Ground Plane antenna or will a regular ground plane antenna work because I'll be installing it on the sheet metal fender (actually to a metal bracket that goes between the fender and front hood - but bolted to the van metal)? Which type of antenna would work best installing it that way? Is it better to use a No Ground Plane antenna because of the small amount of metal on the front of the Class C?
Advice/suggestions would be greatly appreciated!
2015 Forester 2301 - Chevy
Skip & Deb
08-14-2015, 06:30 PM
Cyber Phrenologist
You don't need a "no-ground-plane" antenna. The cab of the rig will provide enough of a ground plane.
Get a 5/8 wave, center loaded antenna. The radiation pattern is circular, (Omni-directional) and the power is radiated at a lower angle, meaning less power is wasted going up in the sky. There's no one up there to talk to.
Any good truck stop will have them.
KU4OJ
2008 (or is it 2009?) Rockwood 8280SS - 2022 F-250 7.3L
08-14-2015, 06:39 PM
Antenna mount
You should also be able to purchase a custom stainless mount for your antenna. It'll be made specifically for your vehicle and be pretty much plug & play. Just follow the instructions and your antenna will be perfectly vertical as it should be. Should be able to buy the mount for about $20, and it won't rust!
Should mount in the hood lip and may even use existing bolts.
A CB store/truck shop is a good place to look, or you might google or use eBay as a source. As "Radio" commented, you'll have a ground plane with this type of mount so any regular antenna cut for the CB band should work fine.
08-15-2015, 04:29 PM
Thanks for the input, I appreciate it. As much as I don't really like the look of the fender/hood mount, I don't think I have any other viable options as long as I don't want to drill into the coach body.
I wasn't sure if I needed a NGP antenna or not, you cleared that up for me.
Skip & Deb
08-16-2015, 02:10 PM
Look at other options
i wouldn't be overly concerned about how much antenna you get above the cab. The cab is probably plastic or some man made product and will not have much affect on your system.
If you have a window in the cap think about a glass mount antenna, they work well for a couple of miles in most directions.
If you really want it up high like an 18 wheeler then most cb shops will have a plastic side mount but will require you to drill holes in your cap. A lot of the newer tractors have these and they get the antenna much higher than the mirror mount.
If the shield of your coax can be at frame (ground) potential then there is no need for a special no-ground antenna.
You know that anything less than a full 8 foot antenna is going to be a compromise antenna, you just have to decide how much compromise you can live with. I use a handheld inside my TV and that gets enough info when the highway turns into a parking lot.
Nick, Sharon and Finnigan
08-16-2015, 03:36 PM
Sent you a PM with an offer you can't refuse!!
08-16-2015, 06:21 PM
Thanks - I'm more interested in listening to traffic problems than talking to anyone on the radio so reception is more important to me than being able to talk to someone 10 miles down the road. That and being able to get NOAA weather on the radio and I'll be a happy camper.
I'm thinking a regular (adjustable tip) 4' Firestick mounted on a fender/hood bracket on the left side will do the trick. The nose on the Chevy sticks out a good distance past the the overhead part of the coach so I should have enough antenna to receive with. I just wasn't sure if the amount of metal on the van nose was enough to use a regular vs no ground plane antenna.
Skip & Deb
08-16-2015, 06:22 PM
PM back at you.
Skip & Deb
08-16-2015, 06:57 PM
Here's what I'm thinking -
Skip & Deb
08-16-2015, 09:24 PM
When I owned our Lexington this was what I did. Worked excellent and I used a 4' antenna with heavy duty spring. Go for it Captain.
Bruce & Nancy Richardson
Lexington GTS 300 S/S
Chevy Avalanche
Jeep Wrangler
Honda Goldwing
08-16-2015, 09:27 PM
07 Coachman Legend 42`
Personally, I think the mirror mount would be sufficient for what you're looking to accomplish, as in listening in on weather/traffic. The hood mount will look bad on such a beautiful rig and may cause paint damage.
You can always call the guys at Firestik...they are great and very helpful. I installed a NGP Firestik on my Georgetown XL and had a couple questions and they were very helpful.
You could always put dual mirror mount antennas on for added receptive assurance.
TrippinOnIt
2005 Georgetown 342DS XL
1987 HD Ultra Glide Classic
08-16-2015, 09:30 PM
I couldn't find a mount (anywhere) that would fit my mirrors, the reason I went with hood. Mirrors arms are too wide.
Chevy Avalanche
Jeep Wrangler
Honda Goldwing
08-16-2015, 09:49 PM
Understood. We have a local radio shop that has every kind of mount imaginable, maybe they can help if you give them specs of your mirrors. They are: Hirsch Electronic Sales Co., 219 California Dr., Williamsville, NY 14221. 716.632.1189
I also purchased items from Walcott Radio, 563.284.6051 walcottradio.com and they were very helpful.
Good luck!!
TrippinOnIt
08-16-2015, 10:02 PM
I searched from online to radio shack, everywhere, I have since traded Class C for Allegro Class A. Maybe Captain will have better luck. Thanks for the heads up.
Chevy Avalanche
Jeep Wrangler
Honda Goldwing
08-16-2015, 10:39 PM
Mounted mine as per your photo
I mounted mine like your photo on my current Winnebago and it works fine with a 3 or 4 foot Firestix antenna. I routed the coax thru the door molding and tucked into the driver's left side kick panel to the floor. The coax rests on the floor and up to my radio. I mounted my Cobra Classic on a piece of oak and made an up side down "J" shape so it rest in the dog house cover console compartment. The power cord runs under the passenger seat to my dinette where I have a hardwired bus bar for my inverter to the house batteries. Reception is good for 2-3 miles in the city and 20+miles on long open highway. I can post photos tomorrow if you like.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
2020 Camping 0 trips Cancellations 6
08-17-2015, 05:52 AM
Most CB antennae use the ground plane principal where the signal bounces off of the metal surface it is mounted on/over. If the skin of your mh section is plastic or fiber glass, it is invisible to CB so mirror mounting should be fine. Dual antenna systems should be 8 feet apart (a half wave) so tow mirrors can be good. A GOOD CB shop can be most helpful. Class A mh's unfortunately are quite poor for CB use and mandate a non-ground plane setup.
08-17-2015, 06:15 PM
Some parts of our country (NH) have no CB places to go, went out of business. I went to Radio Shack, their now corporate and don't have a clue what a CB is (younger generation).
Chevy Avalanche
Jeep Wrangler
Honda Goldwing
08-17-2015, 06:21 PM
Thanks all, I appreciate the input. I've purchased CB gear from Walcott's in the past, I'll have to give them a call. I tried Firestik but no luck getting a response to emails. Maybe I'll try a phone call.
Skip & Deb
08-17-2015, 06:48 PM
Captain Skip
Make sure your antenna bracket has a good ground. as well ground the radio to the frame of the vehicle. Use top of the line coax like RG8X which can be
bought at any amateur radio store from the antenna
to the radio
2017 Durango Gold G384RLT
Coachmen Owners Association
2005 Ford F350 Dually
W5KAV
Last years Camping 125 days
This years Camping 150 an still going
08-18-2015, 06:11 PM
Cyber Phrenologist
It might be annoying on the drivers side, making you cross-eyed.
KU4OJ
