Old 09-03-2014, 09:27 AM   #11
The GPS traffic system only works if the area you are in broadcasts the traffic alert information. I travel a lot on state highways instead of the Interstates and traffic information is not usually available. As a matter of fact, I have only seen the traffic information once on my Magellan Roadmate and that was in the city of Santa Fe.
Filthy Beast is offline   Reply With Quote
Old 09-03-2014, 11:15 AM   #12
For real traffic you can use Google Maps if you have an Android phone. May be available on the iPhone too, but I don't know. Garmin trafffic only works on major interstates and highways in areas with a traffic radio signal. Google covers most roads; at least anything you would want to get a camper on. The nice thing is, one glance will show you your whole route and any congestion (marked in yellow or red).
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
Old 09-03-2014, 11:31 AM   #13
Arefbee's Avatar
GPS is useful but CB can have a little more info about what lane to get into.
I have heard that amateur radio is a lot of fun. I flew with an instructor who used a radio in his car to make phone calls via his home base station before there was a single cell tower. The problem is that it may not provide decent traffic or local hazard information.
Channel 9 is still monitored in some areas, so if you have no cell coverage you may still be able to get help. If you are doing a bug out after a natural disaster takes down the cell system (and 4G GPS traffic information) it could be even more helpful to have local information.
Channel 19 is still a party line and there are trolls out there (maybe worse than the web!) but it does not hurt to have a plan B.
2011 PrimeTime Tracer 2600rls
2001 GMC Yukon XL 2500, 6.0L 4.10:1 axle ratio
Nights camping 2014 - 17
2013 - 15
Arefbee is offline   Reply With Quote
Old 09-03-2014, 11:38 AM   #14
fmc
fmc's Avatar
I use a Cobra 25 with a Firestick antenna. A CB can be a very useful tool when we are traveling this nations highways.
fmc is offline   Reply With Quote
Old 09-03-2014, 06:19 PM   #15
King Yankee's Avatar
Send a message via AIM to King Yankee Send a message via Yahoo to King Yankee
All great comments. I still have a cb in my mh but I miss the days when traveling and talking with the truckers.
Bruce & Nancy Richardson
Lexington GTS 300 S/S
Chevy Avalanche
Jeep Wrangler
Honda Goldwing
King Yankee is offline   Reply With Quote
Old 09-03-2014, 06:19 PM   #16
Any radio, good antenna and excellent antenna mounting and tuned.
Chevy Avalanche
Jeep Wrangler
Honda Goldwing
Old 09-03-2014, 06:28 PM   #17
kenandterry's Avatar
Truck shops (5th Wheel, Pilot, Flying J) stock a variety of CB equipment.
I had a professional place install my fiberglass antennae to the side of my rig, then ran a good sized ground wire from the antennae plate to the chassis of the engine compartment. (I had the antennae mounted to be 5" taller than my rooftop A/C units to act as a "curb feeler" for low hanging trees and such)
Had an old Radio Shack unit kicking around and use it when we need to know about traffic jams and such.
A small sign in the back window says we monitor CH 19 on a tight squelch in case anyone wants to chat after seeing the sign.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 09-03-2014, 06:54 PM   #18
kc8lvy's Avatar
I just put mine in my truck after it set idle for about 15 years. I drove down I75 from Michigan to Southern Florida. I listened to CH 19 most of the way and it was actually fairly quite compared to 15 years ago. I also have a ham radio that I need to fire up again. My CB is a Uniden Grant with a Wilson 1000 antenna.
Sent from my DROID RAZR using Forest River Forums mobile app
2004 Dodge Ram 2500HD Cummins
2017 Keystone Montana 3820 FK
2009 Harley Davidson Ultra Glide
kc8lvy is offline   Reply With Quote
Old 09-03-2014, 07:41 PM   #19
rattleNsmoke's Avatar
A good CB is fine, but as the OP mentioned, get a good antenna. it is all in the antenna. I run a hot rod modded CB and a K30 magnetic mount and can shout out 10 miles or more depending on terrain and elevation. When the sun flares are active 'shooting skip' I cool. I've reached Texas from my driveway in CT.
rattleNsmoke is offline   Reply With Quote
Old 09-03-2014, 08:28 PM   #20
2007 WildCat 32QBBS
05CrewDually's Avatar
Originally Posted by kenandterry View Post
Truck shops (5th Wheel, Pilot, Flying J) stock a variety of CB equipment..........
Exact reason I put a CB in my TV. If I get a low tire or something else going on, I want someone to be able to let me know.
I too run a K30 magnetic base.
05CrewDually is offline   Reply With Quote
radio
