Old 03-06-2015, 04:23 PM   #1
Cedar Creek Silverback 33IK
I have a question on the auto level system, can I leave the 5th wheel pinned to the truck and hit the auto level button, if I am amply staying one night at a camp ground or do I need to unhook the truck and move it a few feet. The 5th wheel dips down first as part of the leveling process. It is the hydronic system.
Larry
Lgheald is offline   Reply With Quote
Old 03-06-2015, 04:27 PM   #2
Jestercyco's Avatar
I would not leave the truck hooked up. I didn't see what system it is. On my LCI system it starts with a dip on the front and then starts the auto level. sound like it is a LCI.
Jester
2012 Super Crew 4WD 6.7 PSD
2015 Cardinal 3800 FL
2007 Road King Black Cherry-Hers
2007 Road King Blue-Mine
1979 FXS Hot Rod Shovelhead
Jestercyco is offline   Reply With Quote
Old 03-06-2015, 06:37 PM   #3
Yea, autoleveling is designed to be off the TV, I would activate the system when still hooked up.
Kevin
2009 F150 XLT crewcab 5.4L and 3.73
2010 Flagstaff 27 BHSS
tenttotrailer is offline   Reply With Quote
Old 03-06-2015, 07:38 PM   #4
dieselguy's Avatar
It's emphasized pretty strongly in the manual and strongly again during your PDI to always unhook before pressing the auto level button. Unhooking doesn't take 5 minutes ... pretty short time compared to possible system damage if you stayed hooked up.
dieselguy is online now   Reply With Quote
Old 03-06-2015, 08:23 PM   #5
Westielover's Avatar
Have four point LCI and you are to. Unhook and then hit auto level
Westielover is offline   Reply With Quote
Old 03-07-2015, 06:03 AM   #6
Salt Shaker's Avatar
Unhook. Make the truck is clear and steps are up.
Salt
2014 Silverback 29RE, 2014 Ram 2500 CC 4x4 Hemi 6.4 auto w/ airbags, B&W Companion. Saltwater boats and rum like any good pirate.
Lose the 2nd and the rest will follow.
Salt Shaker is offline   Reply With Quote
Old 03-07-2015, 08:12 PM   #7
CMSgt. (Ret) Charlie Brown
CMSgt (Ret) Charlie Brown's Avatar
Definitely unhook. I also have the leveling system (4 point) and I start with nose a little low.
CMSgt (Ret) Charlie Brown is offline   Reply With Quote
Old 03-08-2015, 12:16 PM   #8
Unhook, you never tell how low the front will dip with auto level. We have a 32RK. You can manually level hooked up though which I have done. The walkthrough folks really emphasized the unhook for auto level.
2014 Silverback 32RK, 2011 Dodge 2500 4x4 Diesel
DrippingDuo
Chappy and Liz
Dripping Springs, TX
DrippingDuo is offline   Reply With Quote
Old 03-08-2015, 01:56 PM   #9
MC9
If I just want some stability, I leave the TV hooked up and go to manual. I then just lower the fronts just enough to take some weight off the pin.
MC9 is offline   Reply With Quote
Old 03-09-2015, 11:28 AM   #10
Thanks for the reply, I will NOT auto level with the TV hooked up. Some day I will try the manual jacks down for a quick one night stay.
Larry
cedar creek
