Old 08-04-2010, 08:25 PM   #1
ceiling fan switch
I have a 06 wildcat, i have replaced the ceiling fan switch twice already, and according to forest river there is not a different switch that i can use. Has anyone used a different switch? The original and the 2 i replaced have melted. Fan worked ok on low but on high speed is when it melts. Any ideas would be appreciated
rdsknfn_57 is offline   Reply With Quote
Old 08-04-2010, 08:52 PM   #2
Iggy's Avatar
It could be the switch but if you talk about the switch getting hot may be one of two things.
1. swtich is wired wrong. Is it only a 2 speed fan? 1 pull off, 2, pull on low, 3rd pull fast.
2. It may be that the start/run capacitor may be bad, Have you seen the capacitor? May look like the one pictured here.
Old 08-04-2010, 09:25 PM   #3
Iggy, the fan has three speeds forward and 3 backward, I took the switch out and traced the wires behind the concertone untill it disapeared into the wall, the back of the switch has a wireing diagram on it, when i replaced the switch i did so 1 wire at a time so as not to mix them up. On the wildcat forum other F.R. wildcat owners were having the same problem, Called F.R. today , hopefully they call back tomorrow. Found no relay or capisitor of any kind in the wiring
fan
