Old 04-23-2008, 10:35 PM   #1
gate
center support pole for awning
can someone post some pictures of their center support pole on their awning,
mine came with one but im not sure how it goes on.the previous owner said to keep an eye on it ,he had one stollen while camping and said they were a hot commodity.anyone had one ripped off?
gate33 is offline   Reply With Quote
Old 04-24-2008, 04:47 AM   #2
I have a center support but it's secured to the camper with bolts. I am not able to post pic at this time because my camper is in storage, but may someone else can give you a visual on what they have.
Old 04-24-2008, 07:05 AM   #3
spepi's Avatar
Here you go. Hope this helps.
DW, 2 Teen's, 2 Dogs
2006 Chevy Suburban
3.42 Gears
Prodigy Brake Control
Reese 800lb Weight Dist Bars
Dual Cam Sway Control
2008 Rockwood 2701ss
Mansfield, MA
spepi is offline   Reply With Quote
Old 04-24-2008, 10:04 AM   #4
Send a message via Yahoo to SSport
Ugh....I need one of those sooooo bad, but they aren't cheap.
SSport is offline   Reply With Quote
Old 04-24-2008, 10:44 AM   #5
Yes, that's like mine. I had it installed last year for about $100.00.
Old 04-24-2008, 11:23 AM   #6
powerboatr's Avatar
thanks for posting the pictures, thats what makes this a great place.
KUDOS to you spepi
on ours the most difficult thing was getting the tension correct into the awning tube, i was afraid th eput to much tension on it, we didnt get an explanation on it when we purchased the unit.
then it came to me and put enough to straighten the tube and BAM the awning stayed tight and didnt ripple to much
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 04-27-2008, 06:24 PM   #7
spepi's Avatar
I installed this myself. Its pretty easy to do, and if you look at the cup holding the awning...it may look like there is too much tension, but its perfect...no bounce, and no creases.
2006 Chevy Suburban
3.42 Gears
Mansfield, MA
Old 04-28-2008, 03:13 PM   #8
gate
thanks folks. i will have to look at mine again, it looks a little different than yours but hopefully i can figure it out.
awning
