Old 08-12-2015, 11:58 AM   #21
mjones12's Avatar
A couple of the above posts seem to disagree, so I'm confused. My question is: If I use a 50-to-30 dogbone and then plug my 30 amp PI surge protector into the 30-amp end and then plug in my 30-amp camper, will I be getting just 25 amps?
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is online now   Reply With Quote
Old 08-12-2015, 12:40 PM   #22
TURBS's Avatar
You'll have 30 amps available.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 08-12-2015, 12:47 PM   #23
wmtire's Avatar
Originally Posted by ov845 View Post
Please bare in mind, 30 amp service has a 30 amp breaker and 50 amp service has two 25 amp breakers for service. Using 50 amp for 30 amp service you'll be using only one pole of the 50 amp which will be only 25 amps. If your rig sits in the sun and the A/C is running watch your draw.
Oscar
Happy Camping!
2012 Ram 1500 5.7L 3.92
2015 2809W WindJammer
Husky Centerline WDH
Oscar, I think you may possibly be a little confused on what a double pole circuit breaker is, and the 50 amp service. This post with links may help somewhat.
In a double pole breaker, you do in essence have TWO 50 amp breakers, each one controlling 50 amps per line.
50 Amp Service
Edit: This diagram may also help visualize it better
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 08-12-2015, 01:03 PM   #24
wmtire's Avatar
If I am understanding your question correct, you are wanting to use the dogbone to plug your 30 amp travel trailer and surge protector into a 50 amp campground outlet? I prefer to call a 50 amp service a 50 amp x2 service for everyone to understand. You will have two legs (L1 and L2), each capable of 50 amps of 120 volts at the pedestal. They are controlled by a double pole circuit breaker which controls TWO 50 amp legs.
If this is true and that's how you are connecting, then the dogbone will only use one leg (ex L1) of the 50 amp (x2) service. You will have 50 amps available out of the campground pedestal on that one leg to the surge protector and all the way to your electrical box inside your RV, where there the RV's MAIN 30 amp breaker will control/protect the circuits.
As long as you stay within the same usage as you always do when just using 30 amp service, you are fine...and even if you did overload, then most likely the RV's main 30 amp circuit breaker is going to trip.
The only weak point you could have is the 30 amp power cord from your trailer to the 50 amp outlet, but this is going to be a miniscule problem, if any.Your RV's main 30 amp circuit breaker hopefully will trip, before damage is done to the power cord. As long as you stay within the normal parameters of your 30 amp usage, you will be fine.
I use a dogbone like you are referring to many times, as many campgrounds 30 amp outlets are loose, wore out, or faulty. I hook the dogbone up, then connect my 30 amp RV to the pedestals 50 amp x2 outlet.
Edit: I found this site that explains the various adapters and has schematics of how they are wired internally.
http://www.dmbruss.com/zFullTimeLife...alAdapters.htm
Old 08-12-2015, 02:41 PM   #25
mjones12's Avatar
Thanks, guys. Exactly what I needed to know. I am no longer confused...
at least on THIS issue.
Old 08-12-2015, 02:42 PM   #26
TURBS's Avatar
Thanks, guys. Exactly what I needed to know. I am no longer confusion...
TURBS
2011 32bhok Sabre
Old 08-12-2015, 03:41 PM   #27
wmtire's Avatar
Glad you got it figured out. This is a great link below, that really explains 50 amp x2 service and load balancing with one common neutral wire (which let's you use smaller wire than you would if all 100 amps were on a single leg).
Just something you may want to peruse at your leisure.
Electrical Tutorial - Chapter 3 - 30 Amp versus 50 Amp
Old 08-12-2015, 05:03 PM   #28
mjones12's Avatar
Thanks so much.
