Old 08-05-2015, 09:25 AM   #1
Retired
MainelyUS's Avatar
CG 20amp or 50amp
Sometimes simple questions are not simple when you do not know the answer.
We will be spending 10 days (on business -can you believe it) at a CG which only offers 20 or 50amp/110 elec.hookups. Our Windjammer is 30amp.
Question: with an adapter can I hook up to the 50amp w/o elec problems?
Thank you for your responses.
Happy Trails
2017 Columbus 340RK
GMC Sierra 3500HD Z71 6.6L Duramax/Allison
MainelyUS is offline   Reply With Quote
Old 08-05-2015, 09:30 AM   #2
TURBS's Avatar
With a dog bone adapter yes you can hook to the 50 amp.
I had to do this last week because the 30 amp line was low on voltage.
Walmart or any camping store carries them.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 08-05-2015, 09:33 AM   #3
Phat Phrog Stunt Crew
elind's Avatar
Happy Trails
YES!!!!! The adapter 50 to 30 amp uses one phase of two to power your RV. That is good.
2014 Wildcat 327ck
elind is online now   Reply With Quote
Old 08-06-2015, 10:59 AM   #4
2007 WildCat 32QBBS
05CrewDually's Avatar
Like others have said, pick up an adapter like the one pictured here. I usually use the adapter all the time for a better power source at most campgrounds.
http://ecx.images-amazon.com/images/...L._SL1280_.jpg
05CrewDually is offline   Reply With Quote
Old 08-06-2015, 11:20 AM   #5
Retired
MainelyUS's Avatar
Thanks for all your inputs.....I am picking one up this afternoon
Happy Trails
2017 Columbus 340RK
Old 08-06-2015, 11:34 AM   #6
Plugging In
Happy Trails
As a suggestion, to prevent sparking or sudden surges, switch the 50, 30 or 20 amp breakers off before plugging in or disconnecting your power cord. I also use a voltage meter to see what the readings are before I plug in. Has saved me from some very costly mistakes. Good Luck!
gfarmcafe is offline   Reply With Quote
Old 08-06-2015, 02:37 PM   #7
Retired
MainelyUS's Avatar
I bought a Pro. Ind. SSP50 surge protector with a 30a adapter. 1st thing plugged to make sure everything is OK before connecting power cord to the TT.
2017 Columbus 340RK
Old 08-06-2015, 02:45 PM   #8
DocsDad's Avatar
I have an 50/30 adapter but have not needed it yet. Are you stating that I will get a more even power source stepping down 50 to 30 compared to going direct with 30 amp?
Thanks in advance for clarification.
2016 Forest River Sunseeker 3100SS
DocsDad is offline   Reply With Quote
Old 08-06-2015, 02:49 PM   #9
2007 WildCat 32QBBS
That's what my experience has been. I've been at campgrounds that just running my A/C would cause the breaker to blow in the coach. I used the 50amp to 30 adapter and didn't have a problem the rest of the week.
Most service boxes will have both. Don't ask for 50 or you'll usually be charged more per night. I tell them I'm 30 and if the box has 50, I use it.
Old 08-06-2015, 02:51 PM   #10
DocsDad's Avatar
Got it, thanks
