Old 09-06-2011, 05:56 PM   #21
I have a Gentron Pro2 3500 watt RV generator, with a dedicated 30 amp RV plug in, and a 115v 15 amp plug in, as well. it is stated as a 67 db sound level, and has electric or rope start. As much as I will be using a generator, this works perfectly fine for me-I can't afford a Honda or Yamaha, for twice the price per watt. Not gonna happen! I don't even use it until my battery power becomes depleted when dry camping. Never heard any gripes about noise. You could put the genny in the bed of your truck, and with a cover on the truck, face it towards the woods. Randy
Old 09-06-2011, 07:16 PM   #22
dretired's Avatar
Originally Posted by mtnguy View Post
Huh ?? The info I came up with:
The Honda 3000: 58 dB at full load, 49 dB at 1/4 load.
The Champion 3500: 68 dB (???) at 1/4 load (???).
That is a huge difference. I can't find decibel stats on the Champion website......I wonder why ?? Honda and Yamaha both have their levels listed.
A fellow came up to me as I was starting my Yama over the weekend, and asked me all sorts of questions. Seems like is in the market for a generator, and was impressed with seeing me start mine (1 pull), and also the low noise level. He did not want want the noisy generators that many campers use.
I called today and talked to the reps at champion.... and the model i am refering to is 68db at full load
dretired is offline   Reply With Quote
Old 09-06-2011, 07:19 PM   #23
dretired's Avatar
Originally Posted by dimurrrw View Post
Nope. But two of them will, if linked together.
and a cost of about 4 times as much !!!
Old 09-06-2011, 07:28 PM   #24
bikendan's Avatar
want to make sure you understand how decibel ratings are done. they are logarithmic and double every 3dbs, i think.
so, a difference of 10db, is a lot louder. and an inverter generator will be even quieter if it's just being used for recharging or lighter loads, whereas the Champion will be at the same loudness, no matter the load.
i highly recommend you actually listen to a Champion 3500 and a Honda or Yamaha.
quiet isn't cheap but IMHO, is worth it.
if i boondocked or used it at races, i'd have no problem with the Champion.
but i believe we all should respect other campers who'll have to listen to it. i don't want to be one of those that the others complain to the park staff about.
Old 09-06-2011, 09:27 PM   #25
softwarejoe's Avatar
I have the champion 4000 and outside it sounds like my lawnmower. Inside it sounds like the water pump for the tt. I think its worth the $300 and it runs my air so good for boon-dock n it.
Moose Jaw Saskatchewan
2012 Surveyor 305 B-309
2010 F-150 4x4 supercrew Lariat 5.4 3.55 ratio
Power moon roof and back window
TV GVW without me 1/4 tank 5870 lbs
Days camping 20011-4 2012-26 2013-29
softwarejoe is offline   Reply With Quote
Old 09-07-2011, 05:15 AM   #26
dretired's Avatar
I HAVE listened to the honda 3000...nice unit... quite...hopefully reliable...And i will try and listen to the champion model that i am interested in, before buying.The only "boondocking " i can forsee us doing, is at a walmart parking lot.. If we cant make it to a campground that has electric . The only time i would cosider using a generator at a rv park is if the park lost power due to a storm..So do i need something that quiet ??? If some one wants to GIVE me the extra $1500 to purchase quite i will gladly accept it !!!
Old 09-07-2011, 06:27 AM   #27
Flagstaff 625D Popup
Assuming they use an audio scale like dbA, then 6dbA is double. i.e. two generators at 60dbA will generate the same noise as 1 generator at 66dbA. But 6dbA does not "feel" twice as loud.
Edit: I found this.. which I "think" has the story straight
The constant unsureness in the answer to the question:
"How many dB is doubling a sound"?
Answer: Doubling means the "factor 2". What does doubling of a "sound" mean?
Twice the (sound) intensity is obtained by an increase of the (sound intensity) level of 3 dB.
Twice the sound pressure is obtained by an increase of the (sound pressure) level of 6 dB.
Twice the loudness feeling is obtained by an increase of the (loudness) level of about 10 dB.
Bean
bean is offline   Reply With Quote
Old 09-07-2011, 06:37 AM   #28
dretired's Avatar
I will NOT be purchasing 2 generators ..unless someone wants to give me like $4000 !!!
Old 09-07-2011, 08:02 AM   #29
Wanna Be Camper
SaskCampers's Avatar
I totally understand your sentiment about spending the $$$ that a Honda or Yamaha cost and if all you ever do is wally world boondocking well for me even that would drive me nuts. What jars my jitlins though is the fact I took others and us into account and spent the $$ on an Eu3000is Honda so we could enjoy our boondocking and then people come along and fire up their $300 Champion genny and we have to listen to it all day and evening while our Honda sits in the bed of our truck and you can only hear it when you are beside the truck. We actually had a woman comment when she heard it at a provincial campground last year.. Wow that thing would put you to sleep. Not to mention it will run up to 20 hrs on a tank of fuel.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 09-07-2011, 08:05 AM   #30
MtnGuy's Avatar
Another thing to consider here, is how are the non-inventor generators going to affect the electronics in the camper. It is not going to take too many wasted TVs or appliance circuit board replacements to make up the difference in prices.
