Old 10-10-2010, 01:04 PM   #1
chock blocks
We're thinking of getting the X-Chock Tire Locking chocks for our 2304S - anyone know if these fit this model of the Rockwood Ultra-Lite? Or, any better recommendations? Thanks!
Jeff & Mary
jmlocke is offline   Reply With Quote
Old 10-10-2010, 07:38 PM   #2
If you have dual 14" tires as I do, then YES, they work great. I only use one on the door side, but I plan on getting another one. They do help stop the rocking very well. Randy
Old 10-10-2010, 07:49 PM   #3
chock blocks
Thank you! Good to know that both sides are the way to go, too!
Jeff & Mary
Old 10-11-2010, 09:56 AM   #4
The only thing that you need to be concerned about is the distance between the tires. The chock blocks must be less than that distance when collapsed, otherwise they won't fit between the wheels. Most trailers are at least 3 or 4 inches but a few are considerably less.
...VTX-AL
VTX Al is offline   Reply With Quote
Old 10-11-2010, 10:05 AM   #5
chock blocks
Gotcha! We'll wait to get it before we purchase any blocks, thanks!
We've never had a rig with tandem tires before - either campers, MH's or
single axle trailers!
Jeff
Old 10-11-2010, 02:53 PM   #6
Made my own with peices of 4 X4 7 1/4 " wide at top and cut to 20 degrees. drill 1/2 " hole tru the center and a 17" piece of all thread. I put nut and flat washer on top and bottom of bottom peice and just a flat washer and nut on top of top piece. Works great and not expensive.
bill and theresa is offline   Reply With Quote
Old 10-11-2010, 04:03 PM   #7
making your own chock blocks
Great idea, thanks for sharing!
Jeff
Old 10-11-2010, 06:48 PM   #8
backin15's Avatar
The tires on my new Flagstaff are quite close together. The BAL X-Chocks are the only ones that would fit and they work well.
backin15 is offline   Reply With Quote
Old 10-11-2010, 06:50 PM   #9
chock blocks
Good to know! They're on sale right now at Camping World!
Thanks again for the info!
Jeff
Old 10-11-2010, 07:55 PM   #10
Rotochoks are the only way to go!!
Tim and Deb Smith
2011 Rockwood Windjammer 3008w
2011 Chevorlet Sliverado 2500 HD
tls5150 is offline   Reply With Quote
