Old 06-12-2015, 02:13 PM   #11
That is a option on some trucks but living in the country and using the 4 wheel at times year round I didn't want to loose the clearance.
jahottub is offline   Reply With Quote
Old 06-12-2015, 03:47 PM   #12
Islander's Avatar
bob Caldwell.....
There is a deal for the BC Ferry starts June 17th tru to Sept 13th
Called Size up the Savings
see here >> Home | BC Ferries - British Columbia Ferry Services Inc.
Usually in prime season rate is $6.25 per foot over 20ft.
Deal rate is $2.00 per ft. over 20ft.
however, it is Wed eve or Sat morning sailings...See restrictions.
Diesel $1.16.9 per liter lately.
Islander
'07 WildCat 30 RLBS ~ West Coast Edition ~
Trail Air - Tri Glide Pin Box
2000 F350 Lariat DRW 4x4 7.3 Diesel 89k miles
Edge programmer, 4" SS exhaust turbo/back,
Tru-Cool Max Trans Cooler, Bilstein Shocks
Vancouver Island, B.C., Canada
Islander is offline   Reply With Quote
Old 06-12-2015, 07:11 PM   #13
My concern is the height of the trailer. It is about 13'5". Previous owner installed an AC in the bedroom which added 8-10 inches to height.
dmac1951 is offline   Reply With Quote
Old 06-12-2015, 08:09 PM   #14
That is getting up there. If the ac is in the front and you are only raising the rear it will not effect the front height to much. You would have to have someone to take a good look at it to advise you on what options you have.
Old 06-12-2015, 08:15 PM   #15
B and B's Avatar
I had 4 inches and went to Goshen and had a lift kit installed, bolt on, warranty approved. I then had 6 inches with the F 150 and towed. The new F 250 box walls are 2 inches lower and I have 8 inches now and a level towing. I would make sure not being too high as teh rear axle and tires will take a beating.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 06-13-2015, 02:43 PM   #16
Telstar's Avatar
The minimum recommended clearance between the truck rails and the trailer is six inches. I would adjust the hitch plate so the trailer is as level as possible, however it should never be lower in the front.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2005 F-350 6.0 psd CC SRW
PullRite Super 5th
Telstar is offline   Reply With Quote
Old 06-13-2015, 02:59 PM   #17
Smile
Thanks for all of the help. Lowered my hitch in the bed to the lowest holes and I have about 7-7.5 inches of clearance. Measured the trailer height and it is about 13' 2". Only slightly nose up, but I can live with that.
Love this forum---I have learned so much. Thanks and have a great day!
Dwight
wheel
