Old 07-17-2016, 10:22 AM   #11
Flybob's Avatar
Put fan on auto see attached.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 07-17-2016, 09:33 PM   #12
Originally Posted by kantonburg View Post
So my wife and I started moving what we had from our pup to our new TT. I plugged up about an hour earlier and let the A/C run. While on the inside it got quite cool (which I like) and the wife wanted it to bump up a little and cut out the noise for awhile. So I bumped up a few degrees and could hear the compressor turn off, but the fan still ran. My thermostat only has (Fan Only, Furnace, and Cool) as options.
If I bump up say 5-8 degrees does the unit ever shut off. After about 15 minutes I bumped it back down and could hear the compressor kick back on.
This is for a 2017 Cherokee Grey Wolf Limited 26BH
Now they are all different, but our2017 Sandstorm TH has one Dometic ducted AC . Baffled me at first. Thermostat lights up three choices. Fan, Heat Cool. Stop on fan and there are choices. Hi low and auto. Mine seems to cool faster on high, but unless you are on Auto, fan will not stop.
New toy. New stuff that I am still discovering. Good luck.
Tom48 is offline   Reply With Quote
Old 07-17-2016, 09:36 PM   #13
Originally Posted by Flybob View Post
Put fan on auto see# attached.
Fly Bob,. Do you just know all this stuff or just do really good, fast research?
Old 07-17-2016, 10:29 PM   #14
Same thing here. Hooked up today and cycled through the HI, Low, and AU. All good now
kantonburg is offline   Reply With Quote
led
