Old 07-21-2016, 09:02 AM   #1
Burnking's Avatar
Co/Propane Detector
Have a new Rockwood Mini Lite 2304ks. First time boon docking. CO/Propane alarming when battery is on fair. Seems a little sensitive. Is this how it should work? Fair would be better. Any way to silence until running generator?
Burnking is offline   Reply With Quote
Old 07-21-2016, 09:12 AM   #2
Flybob's Avatar
The CO/Propane detector alarms when the battery gets too low to operate properly. This is usually below the level you want to draw the battery down to so as to prevent damage to the battery. If you plan to do a lot of boondocking, I recommend a second battery. I would not recommend disabling the CO/Propane detector. See battery chart below. It is recommended that you do not draw down battery more than 50% on a regular basis.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 07-21-2016, 02:31 PM   #3
Burnking's Avatar
I understand how the system works. However, Forest River panel showed battery was "Good" and then went to "Fair" at which point CO alarm started sounding. I have dual batteries. In my opinion the panel is undependable!! I would think the alarm would sound when panel shows "Low". I have a gauge to check battery voltage and will depend on that from now on.
Thanks for your response!
