Old 02-13-2015, 09:54 AM   #11
I went through all the steps of measuring front and rear- front is comes up a bit and rear sinks the 4"-
jweinzierl is offline   Reply With Quote
Old 02-13-2015, 10:01 AM   #12
That trailer has a fairly heavy unloaded tongue weight right at 15% (815 lbs). Do you know what your loaded tongue weight is?
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 02-13-2015, 10:17 AM   #13
I've never actually hooked it up without the w/d hitch. Should help show me how much help I am getting from the w/d hitch- As long as my truck doesn't flip backwards.
Old 02-13-2015, 10:19 AM   #14
I do not know the actual tongue weight- I was estimating about what you have (815) based on all the weight calculations- and the bars are rated for 1000#
Old 02-13-2015, 10:47 AM   #15
815 is the unloaded weight according to the site I looked at. This would not include Full propane tanks, battery and any thing you have stored in the front of the trailer. Looks like the pass thru storage and under bed storage could add to your tongue weight.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Old 02-13-2015, 10:51 AM   #16
TURBS's Avatar
I'm beginning to wonder what the denali ' s ccc is.
Old 02-13-2015, 10:52 AM   #17
I think the payload with the leveling system was rated at 1900 lbs. I could be wrong (as I am most of the time) but that is what I think I saw on a spec sheet.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2017- 16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 02-13-2015, 11:22 AM   #18
This is from edmunds for a 2005 denali
MAXIMUM TOWING CAPACITY** 8100 lbs. MAXIMUM PAYLOAD** 1457 lbs.
GROSS WEIGHT 7000 lbs. CURB WEIGHT 5543 lbs.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Old 02-13-2015, 11:29 AM   #19
I might have been looking at the XL then. Depending on cargo of the TT and TV the OP may be close or over on weight, this coupled with the removal of factory equipment and addition of shocks could lead to the problems that were posted.
Old 02-13-2015, 11:30 AM   #20
TURBS's Avatar
So let's add 500# to the tongue weight of 815 for propane, battery and user added items and we are at 1315#
I think we've found the problem!
And I think my 500# number is low.
We've not added passengers or gear in the denali yet.
air bags
