02-13-2015, 12:31 PM
#21
Originally Posted by TURBS
So let's add 500# to the tongue weight of 815 for propane, battery and user added items and we are at 1315#
I think we've found the problem!
And I think my 500# number is low.
We've not added passengers or gear in the denali yet.
X2, and even in the XL Yukon it would be cutting it close........
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2018-16) (2017-16) (2016-13) (2015-13)
02-13-2015, 12:44 PM
#22
What kind of wdh do you have?
My dealer doesn't know how to setup a wdh correctly.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
02-13-2015, 01:05 PM
#23
That was my initial concern so I spoke with the service dept at the dealership. They said that 90% of all w/d hitchs they put on are rated for 800lb tongue weight, and only use the 1000 lb a handfull of times.
Thats why I moved on to other issues besides the overloading the w/d hitch.
02-13-2015, 01:09 PM
#24
Unfortunately WD hitches will only aid in an overloading problem, they wont completely fix it.
02-13-2015, 04:49 PM
#25
Hey,they have already (Disabled/Removed) the Factory Auto Level System,now you are going to Blow out his (P-Metric) tires on this Denali! Youroo!!
02-13-2015, 05:28 PM
#26
If the wdh was setup correctly, he wouldn't have 4" of sag. If he has a 815lbs of dry tongue weight and 1000lb bars, the bars are too light. A properly set up wdh would level car, let alone a Yukon. When the auto level was removed were heavier springs installed in place of the stock ones? This would have been a must without the auto level, otherwise you have the basic suspension of a car and lost most of your payload.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
02-13-2015, 05:30 PM
#27
Probably a strutmasters kit I'm guessing.
02-13-2015, 08:56 PM
#28
Oklahoma Proud
Op,
i used air shocks to assist on my wifes old '01 4wd tahoe that was leveled on the front. I never really pulled anything much, but after i leveled the front, the rear would really squat if i hooked up the boat. Most of the time i just pull the boat with my truck, but sometimes when i was pulling the camper, my wife would tow the boat. I don't think i ever added over 50 psi to them and it helped alot.
I'm kinda curious to see how the wifes new Tahoe does with the boat. Of course i haven't customized it......yet
02-13-2015, 10:00 PM
#29
Yes, they were strutmasters. Was that a bad decision?
02-14-2015, 09:22 AM
#30
No, not at all!
I'd just be curious of the spring weight they sent you.
02-14-2015, 03:36 PM
#31
Super springs.com have a few helper options for your vehicle. The sumo springs work great for my Tundra
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
02-16-2015, 03:21 PM
#32
I'll have to check them out- I've seen them on etrailer.com but Ill check them out at supersprings as well.
02-16-2015, 03:31 PM
#33
You can always replace the gas shocks with air shocks. All the El Caminos had them and they worked great! Hauled a 1500# slide in over 40,000 miles using only Gabriel air shocks. The mounts were stock and held up just fine.
02-16-2015, 03:43 PM
#34
Nice scooter
02-16-2015, 10:24 PM
#35
If you have any specific questions, call super springs- super helpful! Even offered an exchange for harder compound if I wasn't happy with their primary product.
02-17-2015, 03:15 PM
#36
I've had air shocks before in an 83 Monte carlo and got about 6 months each out of two pairs- )always pays to get the lifetime warranty at Autozone)
HondaMan174- Did you order directly from super springs- when I went to their site, it didn't appear that anything could be ordered directly from them. I also saw something in the sumo line that repaces the original bump stop with a composite foam that helps support the springs-looked pretty effective as well.
Might be beneficail to call them and talk through the options.
Thanks,
02-17-2015, 03:54 PM
#37
Give them a call- they will sell direct to you. I went with the sumo spring (bump stop) one which has worked well for me. It took pretty much the entire tongue weight of my trailer as I had an issue with a bracket needing to be welded and drove to friends house without the WDH assist. My ass wasn't on the ground so that's a good thing.
02-20-2015, 03:14 PM
#38
Great- Thanks for all the info
