Old 02-14-2015, 02:36 PM   #31
HONDAMAN174's Avatar
Super springs.com have a few helper options for your vehicle. The sumo springs work great for my Tundra
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
Old 02-16-2015, 02:21 PM   #32
I'll have to check them out- I've seen them on etrailer.com but Ill check them out at supersprings as well.
jweinzierl is offline   Reply With Quote
Old 02-16-2015, 02:31 PM   #33
You can always replace the gas shocks with air shocks. All the El Caminos had them and they worked great! Hauled a 1500# slide in over 40,000 miles using only Gabriel air shocks. The mounts were stock and held up just fine.
Name:	72 Camino - Albuquerque, NM.jpg
ID:	69735   Click image for larger version
Name:	72 Camino - Branson, MO.jpg
ID:	69736   Click image for larger version
Name:	72 Camino on the way to Yellowstone.jpg
ID:	69737   Click image for larger version
Name:	72 El Camino with camper as bought.jpg
Old 02-16-2015, 02:43 PM   #34
TURBS's Avatar
Nice scooter
Old 02-16-2015, 09:24 PM   #35
If you have any specific questions, call super springs- super helpful! Even offered an exchange for harder compound if I wasn't happy with their primary product.
Old 02-17-2015, 02:15 PM   #36
I've had air shocks before in an 83 Monte carlo and got about 6 months each out of two pairs- )always pays to get the lifetime warranty at Autozone)
HondaMan174- Did you order directly from super springs- when I went to their site, it didn't appear that anything could be ordered directly from them. I also saw something in the sumo line that repaces the original bump stop with a composite foam that helps support the springs-looked pretty effective as well.
Might be beneficail to call them and talk through the options.
Thanks,
Old 02-17-2015, 02:54 PM   #37
Give them a call- they will sell direct to you. I went with the sumo spring (bump stop) one which has worked well for me. It took pretty much the entire tongue weight of my trailer as I had an issue with a bracket needing to be welded and drove to friends house without the WDH assist. My ass wasn't on the ground so that's a good thing.
Old 02-20-2015, 02:14 PM   #38
Great- Thanks for all the info
air bags
