03-22-2018, 11:27 AM
Cold weather pick up/PDI
Being in Ontario - Canada, the weather at this time of year is unpredictable at best. Day time temps in the +5 to +10 range can still equate to night time temps below zero (Celsius)and there is still a decent chance of snowfall some time in the next 3 weeks or so.
Because of this I have a question around the pick up of our new trailer that we have scheduled for Tuesday of next week (March 27th). I am assuming that if I want to have a full and proper PDI/walk thru/“this is how everything works” session with the dealer it will require the trailer to have been “de-winterized” so that the water pump for the fresh tank and the water heater can be tested and the plumbing in general can be checked for leaks.
That being said, after the pickup the trailer will be sitting on an open lot for a month before we can do our first trip. So - do I leave it de-winterized, even tho it will experience sub zero night temps for part of that month, or should I “re-winterize”?
We are total newbies here so any advice would be welcome, including what level of re-winterizing would be appropriate should be take that route.
2017 Rockwood Signature Series Ultra Lite 8324BS - 2017 Ram 2500 4x4 Cummins Diesel.
03-22-2018, 11:39 AM
Grammar Pedant
PDI in freezing temps.
I failed to provide an update, so I'll do it here.
I was able to test everything but the water heater. The water system was shown pumping anti-freeze. I didn't demand a de-winterization, demo of heated water, and a re-winterization. Maybe I should have, but I didn't.
My PDI was in an enclosed heated shop (with about 10 bays). It lasted about an hour and we covered EVERYTHING inside and out. Tried every drawer, knob, and electrical appliance. Furnace, microwave, all burners, oven, A/C, and on and on. No stone unturned, other than the aforementioned water heater.
Positive experience.
I drove it home, went to a pressure wash car wash, and spent a lot of time washing off all of the road salt and grime.
Good luck.
Former RV: 2018 Rockwood Mini Lite 2504S
03-22-2018, 11:44 AM
Ideally, the dealer will test with a winterized solution in the system. Then all you need do is flush the system prior to your first trip. We took notes during the walk through as there is a lot of information to process.
03-22-2018, 12:51 PM
I did winter PDI. Trailer was winterized and they did not dewinterize. I was too new to know any better.
I got lucky and had no issues with water heater and the lines were pressurized with the antifreeze so I made out ok.
If I were to do it again I would bring antifreeze and have them drain it and pressurize and walk me through rewinterizing.
03-22-2018, 12:59 PM
We did a PDI on our new coach a few weeks ago. It was set up inside one of the service bays. They had the water system ready with the water heater on before we arrived. Dealer re-winterized after we were through.
____________________
2017 Silverado 3500 Z71 CC / L5P Duramax/Allison
2018 Grand Design Reflection 311 BHS
2015 Coachmen Apex 259BHSS 50th Anniversary (sold)
03-22-2018, 01:01 PM
2400W
I took delivery of ours Friday 13th, 2017, in a heated garage. They had both city and tank water systems going with W/H on for the delivery. After all was done they ran the pink through everything and labeled the door "winterized". It stayed that way till mid March when we took her south. Not a hiccup since we got it P T L !!! Have had it out on freezing nights with only one frozen water hose connection. Remember to keep it dripping !!
03-23-2018, 01:39 PM
Denver, CO
Make them dewinterize, run through ALL the systems and then winterize again and let them show you how. It should only take a few minutes and a gallon or so of antifreeze. It will be good experience.
2017 Fuse 23T
03-23-2018, 11:46 PM
X2 what garbonz said . . .
McCormickJim
2017 GT 31L5
03-24-2018, 10:38 AM
Sounds like you have a Good Dealer !!!
03-24-2018, 09:32 PM
What if the lines were pressurized with air from the factory. Wouldn’t a hissing if you turn the faucet indicate a non leaking system?
Let’s go camping!
03-24-2018, 09:56 PM
That would tell you plumbing does not leak. They would typically bypass the water heater and you would not know if the water heater worked or leaked.
03-24-2018, 10:12 PM
Gottcha.
Let’s go camping!
03-25-2018, 09:19 AM
I understand the way they test units @ the factory is with air ???
Not sure that is the greatest of all ideas ???
03-25-2018, 09:54 AM
They test new houses with air before they connect to water. Pressurize the system with a gauge on it, come back a few days later to check the pressure. By using water, you wouldn't necessarily see a drip hidden in a wall.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
03-25-2018, 10:14 AM
Very true sometimes,,, but RV builders do not wait a few days,,,
Maybe a few seconds ???
LOL !!!
The kid that worked for the plumber when our house was built turned the water on and left,,, I met him on the road as I was coming to see how things were going,,, when I got here I had to turn the water off and fix 4 leaks !!!
The builder walked in as I was fixing the leak under the Dishwasher,,, he said what are you doing ??? After I told him what I and found,,, he went and called the plumber,,, sorry to say the young man lost his job !!!
