Old 04-17-2019, 10:08 AM   #1
Coleman Mach heat pump quit
Got up this morning turned on Coleman Mach electric heat and it came on for a couple secs and shut off. I turned the thermostat up 10 degrees and nothing. The AC works fine. Breakers are all good.
jdkbrooks is offline   Reply With Quote
Old 04-17-2019, 10:21 AM   #2
cavie's Avatar
folowing
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 04-17-2019, 11:27 AM   #3
Originally Posted by cavie View Post
folowing
Ok?
Old 04-17-2019, 11:35 AM   #4
cavie's Avatar
Originally Posted by jdkbrooks View Post
Ok?
It means I don't have a answer for you but want to see what the problem is so I will get email notification.
FYI, You have a heat pump system Possibly with a backup aux small heat strip that runs with the heat pump compressor. Don't know what T-stat you have so I can't help you.
Old 04-17-2019, 11:38 AM   #5
FYI, you don't have electric heat. You have a heat pump system Possibly with a backup aux small heat strip that runs with the heat pump compressor. Don't know what T-stat you have so I can't help you.
It's an RVComfort.HP Coleman Mach
Old 04-17-2019, 12:28 PM   #6
Bluepill's Avatar
Does it function on A/C setting?
Bluepill is online now   Reply With Quote
Old 04-17-2019, 12:47 PM   #7
folowing
FYI, another way to do this is - At the top select thread tools then subscribe.
Sealyn is offline   Reply With Quote
Old 04-17-2019, 04:07 PM   #8
Yes works fine on AC
Old 04-17-2019, 04:21 PM   #9
Bluepill's Avatar
The first thing I would do is to get a wiring diagram for the thermostat circuit. Possibly online, owners's manual, or wiring diagram in the unit itself.
Identify which wires control the heat function, then jumper them to eliminate the thermostat as a suspect. This can only be done if the thermostat is traditional multi-wire type. A digital thermostat only sends signals to the controller board in the HP unit, and cannot be bypassed this way.
pump
