Old 09-16-2019, 08:35 AM   #1
Coleman Mack Thermostat
I want to swap out my analog thermostat for a digital unit. I have seen it discussed on the forum but can't find the link.
It looks like a simple job to me as long as I get the correct thermostat.
BTW I have a 2015 flagstaff.
Days camped, 2005 26, 2006 29, 2007 41, 2008 41, 2009 34, 2010 54, 2011 39, 2012 36, 2013 47, 2014 44, 2015 39, 2016 45 2017 24 so far...
larrybessette is offline   Reply With Quote
Old 09-16-2019, 08:42 AM   #2
cavie's Avatar
Youtube is your friend. Follow the Youtube directions. Not the wiring directions that come with the new T-stat. You need a battery operated Honeywell t-stat.
here is one. Honeywell is about $30.00 cheaper than the Coleman Mack replacement. I don't use low seed either. I find it quiet with the dump vents closed.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 09-16-2019, 08:52 AM   #3
Digital Coleman T-Stat
This was a wire for wire easy swap for me. My unit did not have the heat pump however, yours may.
2020 Rockwood Mini Lite 2509s
2019 F-150 3.5 EB SCREW Max Tow - 1797 payload
Blue Ox SwayPro w/ 1000 lb bars
s1njin is offline   Reply With Quote
Old 09-16-2019, 08:57 AM   #4
Ejs4029's Avatar
If you want to stay with a Coleman you can get this one it's a wire for wire switch over very easy to do. This is the one I purchased and it works great.
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30C
Ejs4029 is offline   Reply With Quote
Old 09-16-2019, 11:21 AM   #5
Coleman thermostat
Thanks. Coleman unit on the way.
I decided to install the Coleman because I do use the hi /lo function at night.
Old 09-16-2019, 03:56 PM   #6
RangeMaggotBob's Avatar
That's the one. Did it ourselves recently. Like Larry said- YouTube. For everything!
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2000i generators
RangeMaggotBob is offline   Reply With Quote
Old 09-19-2019, 08:55 AM   #7
WFD
I have swapped the thermostat with this exact one on our last 2 trailers, works so much better and much less variance in temps. One member on the forum suggested that while you have the old thermostat removed fill the cavity in the wall with a bit of fiberglass insulation. The wall cavities, depending where your thermostat is located, can get very warm or cold depending on time of year. Just feel inside your cupboards on a very hot day to see how warm it is there. The trapped heat or cold in that wall coming from the sizeable hole they sometimes make to run the wiring, could fool your thermostat's ability to read ambient air temps, thereby throwing it off. Made sense to me so I did just that. Anything to help the thermostat be as accurate as possible just helps with making the trailer more comfortable. Thermostat you ordered is much better than the factory one and has a much smaller temperature variance for cycling.
You may also want to tape the wires together once the old one is removed to prevent any wires from slipping down the hole in the wall.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 09-21-2019, 12:20 PM   #8
Can these be set to not run for, say, two weeks and then come on? We use our rv every other weekend and would like to have it cool when we get here, but we don't have wifi here.
Dave Caddell is offline   Reply With Quote
Old 09-21-2019, 06:46 PM   #9
WFD
Not the one pictured in the previous post. It's not programmable, It's simply a digital thermostat with a much smaller variance in temps for cycling on an off then the factory installed analog thermostat.
coleman, thermostat
