Old 05-02-2016, 05:36 AM   #1
shorthorn's Avatar
Coleman nxt grill
We have been using our Coleman NXT 100 grill for several years now, it's been great... our new 5er has a quick connect to the gas line... has anyone figured a way to connect this grill to the 5ers low pressure gas instead of the little 1 lb bottles?
2014 RAM 3500 4x4 CCLB Dually, Cummins / 68RFE / 3.42 / B&W Patriot 16K
2016 Coachmen Chapparral 360IBL
SOLD - 2012 Salem Cruise Lite 281BHXL
SOLD - 2005 Dodge Ram 2500 4x4 QCLB Cummins
shorthorn is offline   Reply With Quote
Old 05-02-2016, 06:08 AM   #2
Who Dares, Wins
doc73's Avatar
Coleman XLE Grill to RV LP Quick Connect
This is a thread about it some time ago. There is also two YouTube videos of a conversion if you search it. Pretty easy once you get the parts needed.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 05-04-2016, 07:55 AM   #3
Does the grill have a pressure regulator? If so, then you will need the extended stay kit so that you can T off a line before the pressure regulator on the RV. Otherwise the gas will be double regulated and it won't work.
http://amzn.com/B0014JG7RQ
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
Old 05-04-2016, 08:00 AM   #4
shorthorn's Avatar
Gmacklem, u are right... good point... I could do the extended stay kit, or bypass the grills regulator.
