Old 01-04-2016, 11:49 AM   #1
Condensate inside camper
I have just made my first ever cold weather trip. There was considerable condensate on inside walls with an outside temp of 38 and inside temp of 67. Is this normal? What to do to prevent this? I have a 2015 Hemisphere TT. Thanks for the input.
Matheny9 is offline   Reply With Quote
Old 01-04-2016, 12:03 PM   #2
Fulltime family RVer
It is normal. Either run a dehumidifier OR crack a window open and let some moisture exit.
I actually am dealing with condensation for the first time at this location (similar temps).
Old 01-04-2016, 12:09 PM   #3
The only time I have this issue is when I use the cook top. My furnace is vented so no issue with it. If you use the cook top make sure you use the stove vent fan (don't forget to open the vent door outside) since H2O is a by-product of combustion. I sometimes slightly open the bedroom vent also if I am boiling water or anything steamy. I close it as soon as I am finished cooking. I use mine all hunting season and this has worked for me.
limblips is offline   Reply With Quote
Old 01-04-2016, 12:19 PM   #4
BendOrLarry's Avatar
The weep holes in the windows freeze so moisture that runs down the window can't get out. When we camp in the winter we put towels at the base of windows to catch the water and then take them out at the end of the trip. Cold out, warm inside you will get condensation.
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
BendOrLarry is offline   Reply With Quote
Old 01-04-2016, 06:26 PM   #5
Leave one or two roof vents cracked at all times to let out the moisture. Run vents when showering or while cooking to vent steam and humidity. We have had very little condensate issues since we started this. Good luck.
Sierra360PDEK is offline   Reply With Quote
Old 01-05-2016, 12:14 PM   #6
NINA's Avatar
Great little dehumidifier here. Come in different sizes. Eva-Dry.
Bob & Nina's Bunkhouse
1970's Coachman Crusader 30ft TT
Add In: Sarina (18), Susan (14), and dogs Midnight & Shadow
Hitched up to a White 1999 F-150 Ext. Cab
Number of days camped in 2014-2
(4 more days reserved)
NINA is offline   Reply With Quote
Old 01-05-2016, 01:21 PM   #7
mjones12's Avatar
We use that same Eva-Dry model. Takes a load of moisture out of the air. Probably need a couple of them for larger campers.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 01-05-2016, 01:37 PM   #8
Flybob's Avatar
Be sure to check under the mattress. Loads of body moisture penetrates the mattress while you sleep and will condense on the cold bed deck. If you do not lift the mattress and air it out when you get home, you will get mold. If you cold camp a lot, you can put a piece of 3/4 " foam board house insulation under mattress.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
camper
