Old 01-02-2013, 07:10 PM   #11
VinceU's Avatar
Originally Posted by nazrev87 View Post
We have a 2013 Flagstaff TT. We are in Arizona for the winter and have experienced heavy condensation on our windows each night. It has been down around 30 each night and warms up to upper to mid 50's for the highs. We heat with our TT's furnace and I am wondering if condensation on the windows is common or is there a way to help this. I have read that condensation can cause a lot of damage over time and I am wondering if this is something I need to worry about and correct. Thanks for any words of wisdom!!
You really need to get it stopped. Condensation is water, it will get inside the walls via the window frames and just leaching through seams etc. It will cause Mildew, insects and worst of all wood damage with delamination inside and outside sheating. DH is probably your best bet with better ventilation. Don't let it continue all season.
Old 01-03-2013, 09:15 AM   #12
SibeTribe's Avatar
Originally Posted by lindy View Post
SibeTribe, You have a heater with a fan blowing, this could very well be the answer as to why 1 window has no condensation on it and others do - Air Flow as produced by the heater fan, air is likely blowing on this window enough to keep clear, fan doesn't need to be blowing directly at this window to keep it clear. Doubt all your windows except 1 leak.
That's not the window the fan is blowing on. The ones most likely for it to be blowing on are the ones around the dinette because that is the direction the fan is pointed in. You'd be surprised. The only thing different about that window is that it's an exit window. My guess is it's made on a different line or differently. Possibly even a different mfg. The reason I think they leak is that water came in mainly when it was raining. Some condensation when it was cold and dry out. But, also, my indoor humidity was quite low, even when it was cold out.
Sue & Sibes
2002 Ford Expedition XL
2012 Tracer 2700 RES Touring Edition
4 Trips 70 nights
SibeTribe is offline   Reply With Quote
Old 01-10-2013, 01:16 PM   #13
mjones12's Avatar
Originally Posted by caper View Post
Use a dehumidifier. We used one all last winter while camping in BC. We would have to empty the tank once a day and the TT felt warmer. Most of the campers were using dehumidifiers. The people who did not had a moisture problem.
Agreed. Evadry makes a good, small one that we use. Very quite, too. At night we move it near the head of the bed and it eliminates the moisture from our breath.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 01-13-2013, 07:37 PM   #14
Thanks to All
Here I am in Arizona with my BW and our little Yorkie and they are having lows in the 20's, coldest in 20 some years. Thank you for all the responses concerning our condensation on our windows. We BARELY cracked open the roof vent in our bathromm and it has completely taken care of the problem. Now all we need is WARMER weather!
nazrev87 is offline   Reply With Quote
Old 01-13-2013, 09:09 PM   #15
VinceU's Avatar
I know its not funny but AZ weather has been on the East Coast this year!
