Old 01-02-2013, 09:14 AM   #1
Condensation
We have a 2013 Flagstaff TT. We are in Arizona for the winter and have experienced heavy condensation on our windows each night. It has been down around 30 each night and warms up to upper to mid 50's for the highs. We heat with our TT's furnace and I am wondering if condensation on the windows is common or is there a way to help this. I have read that condensation can cause a lot of damage over time and I am wondering if this is something I need to worry about and correct. Thanks for any words of wisdom!!
nazrev87 is offline   Reply With Quote
Old 01-02-2013, 09:32 AM   #2
TURBS's Avatar
Try cracking a window and turning on your bathroom fan to circulate air.
Turbs
Old 01-02-2013, 09:36 AM   #3
puff's Avatar
Run the exhaust fan in the bathroom while taking showers if you have, same for the fan above the stove while cooking. During the day open the blinds and window coverings to let air movement to the windows to help moisture evaporate. Try to keep wet items to a limit inside IE the wet jacket should hung to dry in the tub or shower. Excess moisture on window frames should be wiped off and keep a watch out for things like broken or torn seals around windows, doors etc. It lets in cold damp air.
Keep the air moving with a small fan, it also helps. We live in our unit so I have a small space heater with a fan on all the time.
Glen & Robyn (A.K.A. Puff & Crickit) Full Timers..
2006 F350 6.0 with 3.73 gears, 4X4, Extra-Cab Long Box, Oil/Tranny/P.S. Coolers. Coolant filter. SCT Livewire.
2011 Cedar Creek 36RE, Auto levelers + too much to list..!
puff is offline   Reply With Quote
Old 01-02-2013, 09:36 AM   #4
Love My Sunseeker
DXSMac's Avatar
Buy some Damp Rid thingies at Wal-Mart. Just hang them around.
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
DXSMac is offline   Reply With Quote
Old 01-02-2013, 09:39 AM   #5
Dave_Monica's Avatar
As Turbo has mentioned, crack open a window or roof vent. I also recommend that you periodically open cabinet doors and allow the cabinets to warm up. Any cabinet mounted on an outside will also have condensation on that surface too.
Dave
Old 01-02-2013, 09:48 AM   #6
Basic science would suggest that the humidity in your trailer is too high, cooking and or showering without venting are likely causes. Now depending on how much condensation is forming on the windows is the reason for concern. I don't think the droplets forming on the windows would do any damage to the windows or frames. However my biggest concern would be the cooler area of your trailer, i. e. inside cabinets, drawers closets etc where moisture can condense and start mold growth. I would vent until windows clear. Happy New Year and enjoy the trailer.
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 01-02-2013, 10:31 AM   #7
caper's Avatar
Use a dehumidifier. We used one all last winter while camping in BC. We would have to empty the tank once a day and the TT felt warmer. Most of the campers were using dehumidifiers. The people who did not had a moisture problem.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 01-02-2013, 12:02 PM   #8
lindy's Avatar
Use an elect ceramic heater, crack roof vent 24/7, ALWAY use stove exh fan, if this isn't enough then get a small dehumidifier.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 01-02-2013, 01:53 PM   #9
SibeTribe's Avatar
That doesn't have to be the case. I was cooking with the vent on, not showering and have a humidistat that showed between 46-53% inside humidity as well as a heater with fan blowing. I had one window, the exit window over the couch that didn't have any "condensation." I came to the conclusion that the windows are leaking, it's not condensation. Otherwise, why would one window not have condensation on it?
I had this same brand of window on a horse trailer and they leaked horribly.
Sue & Sibes
2002 Ford Expedition XL
2012 Tracer 2700 RES Touring Edition
4 Trips 70 nights
SibeTribe is offline   Reply With Quote
Old 01-02-2013, 05:42 PM   #10
lindy's Avatar
SibeTribe, You have a heater with a fan blowing, this could very well be the answer as to why 1 window has no condensation on it and others do - Air Flow as produced by the heater fan, air is likely blowing on this window enough to keep clear, fan doesn't need to be blowing directly at this window to keep it clear. Doubt all your windows except 1 leak.
F.R.O.G. member
