10-17-2017, 04:20 PM
Flagman
Connecting (2) #24 batteries to (2)#6 batteries
After reading 7/24/17 post from Jimmoore13 which was excellent, I wondered if it would be possible to achieve more amp hrs. by attaching my(2) 24batteries in series to my recently installed 6v batteries?The 24's are only 1yr. old off my 2015 flagstaff shamrock 23ss. Thanks for any thoughts.Also,what are concerns in running my Honda 2000i to recharge all (4) as hooked up?
10-17-2017, 05:06 PM
Location: Alberta - East of the Rockies, West of the Rest
Yes, absolutely.
You should make sure they are all of the same type, best is to have them all identical incl. age. Connect positive to positive and negative to negative. This way you keep the voltage and double the Amp/h capacity.
Charging the battery bank with a generator is common practice but not very efficient. Depending on the converter/charger in your trailer it might be better to use a good stand alone battery charger to put more amps more quickly back into the batteries.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
10-18-2017, 09:49 AM
I assume you mean group 24, 12 volt batteries.
You don't want to hook them in series to the 6 volt batteries. They'll be parallel, so you'll wind up with a series-parallel circuit. Which will wind up with about output of 12 volts. While not ideal, it can be done.
Gotta go campin!
10-18-2017, 10:01 AM
Be darn sure you have 12 volt output, not 24, before connecting to the trailer!
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
10-18-2017, 10:06 AM
Pay close attention to what Bama has said in this post.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=64
10-18-2017, 01:40 PM
Recently new!
It looks like you are attempting to wire two 6 volts in series to get 12 volts. Then you want to parallel those across the two group 24's (12volts each?) that already been paralleled? I would not do that. Instead, I would suggest an isolation switch and flip between the two banks of batteries as needed. This is due to the different types of batteries, while each bank is 12 volts, they will not be balanced because of internal resistances. One set will always charge/discharge at different rates. Also, you may even experience one set trying to top off the charge of the other set, depleting the host set.
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
Loving wife, R.I.P., 6/6/19
and Mason the always dirty dog! R.I.P, 2/19
10-18-2017, 01:49 PM
X2
2015 silverback 31IK
2023 f350
10-18-2017, 05:01 PM
x3
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
10-18-2017, 05:59 PM
Battery diagram
Here is a diagram of how to make the connections with a marine switch.
10-19-2017, 08:42 AM
Flagman
Connecting (2) #24 batteries to (2) 6v batteries
Thanks for all ideas on this subject.;so many other opinions from RVdealers. I REALLY APPRECIATE the diagram from Jonol as it "says it all".
10-19-2017, 08:16 PM
I would suggest if you are buying batteries to connect via the marine type switch, but get the same Ah of the batteries you already have.
WW
Hyper Lite was sold
10-19-2017, 08:41 PM
6 volt batteries will never reach the volt readings you would normally require for proper converter operation. no matter how many you have. This is because a fully charged 12 volt battery will be around 12.7 volts. Your converter will charge at a volt level of 13.2-13.7v
If your voltage drops to 11.5-12.0 volts, your converter will shift into "bulk" mode at 14.4 volts for a four hour period.
A fully charged 6 volt battery will have 5.5-6.0 volts, two of them in series will produce 11.0-12.0 volts, which will most likely keep your converter triggered in "bulk" mode to attempt to bring them up to a minimum of 12.7 volts, which they won't stay at.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
USS Pyro AE-24 WestPac MM2 '71-'75
10-19-2017, 08:42 PM
No not in series in parallel with a switch as mentioned. The issue trying to charge batteries of different age or type/capacity is that one will charge faster than the other this will result in one battery being slightly overcharged and one slightly undercharged. Each time you charge, the difference increases until the weaker battery is bad and will then damage the good battery. This is a simplified explanation, but essentially what happens.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
10-19-2017, 08:52 PM
Not sure where you got that information for 6 volts batteries, but my 6 volt FLA in series are the same as a 12 volt battery. Because each cell is the same and the quantity of cells are the same. Fully charged series pair is 12.73 volts, the same as a single FLA 12 volt battery. There is a tiny voltage drop in the strap or jumper. Voltages are based on resting for a period of time. SG is the sure way to measure state of charge.
WW
Hyper Lite was sold
10-19-2017, 09:32 PM
WW
I was told that by Brian Moran (who gives the electrical seminars for Forest River)
He said it at Goshen rally and again at the BamaGanza rally a couple weeks ago. I specifically asked him to clarify the comment that he had made at the Goshen rally because it didn't make sense to me. He said it was due to the construction of the battery itself???
10-19-2017, 11:30 PM
I run one 12 and 2 6volts with a marine switch and just change between the two banks as I need.
10-20-2017, 12:55 AM
Wow, Brian should not be giving seminars as he does not have a clue what he is talking about. Two 6 volt jars connected in series is the exact same voltage as a 12 volt jar. Both are 12.7 volts at 100% SOC.
2007 Surveyor SV230 - 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
