Old 11-05-2018, 09:23 PM   #1
Continual war against mice!
I have always tried to seal every entry point that I can find on my camper - screens over furnace openings, over refrigerator grid, etc. Last year, I took off the access panel on the bath tub to see that the opening in the floor for the drain had not been sealed at the factory - big surprise! Thought I had them all sealed last year, but still caught mice inside in traps. Today while winterizing, I discovered that the openings where the vent stacks for the black & gray water tanks go through the floor were not sealed either. I was able to slide a can of Great Stuff foam between the black water tank and the floor to spray the opening. I was able to reach the other one through the access hole on the tub, although it was difficult. I also spray some Great Stuff in the bottom corners of the slideout. Well, I'll find out as I monitor the mouse traps in the camper every few days this winter. It is really irritating that the factory didn't take 5 minutes to seal these openings!
johndeereman is offline   Reply With Quote
Old 11-05-2018, 09:47 PM   #2
Mr Towed's Avatar
Yikes, nice find with those missed areas. I'm actually going to winterize soon and one of the things we are doing is getting all the sheets/ towels/ bedding, etc OUT so it's much less cozy in there if they DO find their way in.
Travel Trailer: 2004 Flagstaff 25LB
New Tow Vehicle: 2017 F-150 3.5 Ecoboost, supercrew short bed FX4 Lariat
Old Tow Vehicle: 2009 Silverado 2500HD 4x4 Ext. Cab Short Bed
Cats: Rhody and Hazy
Mr Towed is offline   Reply With Quote
Old 11-05-2018, 09:50 PM   #3
We are using a product with a peppermint smell called Mouse Mix to deter mice from coming in the trailer.
Driver307 is offline   Reply With Quote
Old 11-06-2018, 12:11 AM   #4
Came across this product called Mouse free I sprayed it on today going to see how well it works it’s supposed to last one year if you trailer and two years if you are parked. Check it out at www.mousefree.com it had a nice peppermint smell.
Polesetter is offline   Reply With Quote
Old 11-06-2018, 01:52 PM   #5
Mice’s like the dark rather than the light. Covering an RV for the winter will also invite them. Sprays and little packages that prevent mice have to be replaced/respirated constintly.
Rogerjs is offline   Reply With Quote
Old 11-06-2018, 02:00 PM   #6
Mice
We've been using cotton balls and peppermint oil in little plastic cups, placed around the inside of the trailer for years. Never have a problem. This also helps with ants. About once a month I go in and add 10 or 12 drops to each cotton ball. We also have an Attack Wave Pestrepeller in there too. I buy the 16 oz canister of peppermint oil from Piping Rock when it's on sale - around $38. Once in a while you can get it for around $33.
Chazman is offline   Reply With Quote
Old 11-06-2018, 02:04 PM   #7
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Mice can squeeze through 1/4" small openings, they can not climb smooth verticals. Disconnect waterhose and powercord, place the landing jacks in 5 gal. buckets they are smooth so that mice can't climb up and build a 8" - 10" tall tub around the wheels from smooth material like tin (not wood or plywood) making sure the bottom is sealed. Don't lean a broom or anything against the trailer that the mice can use as bridge. I used this method for years on the farm after trying everything imaginable, never had a critter since.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 11-06-2018, 02:14 PM   #8
Flybob's Avatar
We have used peppermint oil for the past 10 yrs. No mice despite having them in garage 2ft away. Be sure you get essential oil of peppermint and not food grade peppermint. Also be sure to keep the oil off anything you do not want damaged ( floors, counters etc) and freshen it up every 5-6 weeks. Use old coffee cups or glasses as it will eat through plastic.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-06-2018, 02:25 PM   #9
bedubya's Avatar
I have had good luck with Fresh Cab. https://www.earthkind.com/product/fr...ent-repellent/
Most hardware stores & home centers carry it. But next season, I may try the cotton ball & peppermint oil.
I think Forest River did a thorough job on my camper with the Great Stuff foam.
'17 Toyota Tacoma 4x4
'17 Salem Cruise Lite 232RBXL
'08 Kawasaki Vulcan Classic 1500
Mickey the Rescue Project Schnauzer
bedubya is offline   Reply With Quote
Old 11-06-2018, 02:30 PM   #10
Grapehound's Avatar
We just place packages of D-con around the unit (in spaces out of reach to humans or pets), knowing that unless we build a moat around the RV that some little critter is going to make it inside. A determined mouse can gnaw his way inside the camper. Once they eat the D-con, they get thirsty and go back outside to drink and pass away. We have a bigger issue with squirrels.
A few years back when we had a 33 foot Sandpiper TT, we took it to the shore for the weekend. When we tried to fire up the stove-top we found we had no gas. Upon further inspection, the squirrels ate through the propane hoses by the propane bottles at the front hitch. They have even eaten the engine wiring on my RAM 3500. Nasty critters. They need to eat some acorns since we have six acres of them.
2014 Rockwood Signature 8282 Ultra-Lite
2008 RAM 3500 HD DRW Laramie Megacab
6.7 Cummins Turbo Diesel
Grapehound is offline   Reply With Quote
