Originally Posted by mnolasco
I have a 2016 XLR Thunderbolt 375 AMP, 42-foot 5th Wheel Toy Hauler. I am at a full site with full hookups and the power went out on the entire RV Park. When the power to the RV park was restored, For some reason, my trailer has switched over to battery power and propane power. The 50 amp cable is hooked up and all of the circuit breakers appear to be functioning properly. I called Coach NET and they couldn't tell me where the converter inverter is to switch it back over to shore power. I ran the generator for a while and it recharged the battery but pretty soon my fuel is going to run out. Can anyone help me with this problem?
It sounds like your auto transfer switch is not working (if equipped). This link may help.
http://www.rvtechmag.com/electrical/chapter4.php
When you turned on your generator, did you have to disconnect/connect a power cord or change anything for the generator to provide power?
Have you also verified the circuit breaker at the campground pedestal is not tripped and has power there? If you don't have shore power coming in to your RV, then the problem is there.
