Old 04-27-2014, 05:59 PM   #1
converting Booth Dinette into a bed
OK i'm not new to this I have now had 3 units with booth dinettes that drop down into beds. All were easy remove the pedestals drop the table top down slide the cushions in and drop the seat backrest cushoins down flat. Easy stuff well this Wildcat is not so easy. We had a hardtime firguring uot how the cushions get setup as the backrest cushions are wraparound style.
Doing things the way they were done on our last 2 units we initially came up with this.
Then this..
Obviously niether would not work and would be tough getting a bedsheet on so we ended up turning them over and went with this.
Are me and my wife missing something?
2013 Wildcat 323QB
08 Silverado Crew Cab 2500HD Duramax-Allison
Twin Honda 2000 campsite friendly generators
Nights camped in 2014 = 19
(2013 = 36)
(2012 = 42)
JFM-jr is offline   Reply With Quote
Old 04-27-2014, 06:28 PM   #2
raspivey's Avatar
At least your cushions are all the same thickness! Can't say that for mine. I'd personally go with option 3 there.
Old 04-28-2014, 06:24 AM   #3
mlong's Avatar
Do the cushions get turned 90 degrees? Does the owners manual show anything?
2012 Chevy Silverado Crew Cab Short bed 5.3L v8
2014 Prime Time Manufacturing Avenger ATI 27BBS
mlong is offline   Reply With Quote
Old 04-28-2014, 07:39 AM   #4
cat1956's Avatar
My problem with my u-shaped dinette was the back cushions was thicker than the seat cushions. My solution was ordering a custom cut cushion that would fill the space.
Tommy and Wanda
2014 Flagstaff 27RLWS
2017 Ram 1500 5.7 Hemi
Equal-i-zer 1,200/12,000 Weight Distribution w/ 4-Point Sway Control
cat1956 is offline   Reply With Quote
Old 04-28-2014, 07:41 AM   #5
mlong's Avatar
On second look, you may have already tried turning the cushions.
Old 04-28-2014, 07:43 AM   #6
dcheatwood's Avatar
It looks like the bottoms should slide together in the center, then put the backs on the ends. Jmo.
Sent from my XT907 using Forest River Forums mobile app
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 04-28-2014, 07:55 AM   #7
mlong's Avatar
Try posting in this thread. It is a Wildcat factory rep.
Ask the Wildcat factory...
Old 04-28-2014, 11:24 AM   #8
raspivey's Avatar
I had the same problem. Ended up adding 1x2 below the bench frame on the inside for support and just moved the table rails on the benches down about an inch so the table sat lower.
This is just something nobody ever thinks to go over when picking up a new trailer....I mean, how hard can it be to put down seat cushions?
Old 04-28-2014, 06:51 PM   #9
gooiebob's Avatar
I put up with the uneven cushions last year but this year I moved the support rails down one inch so the table is lower. Like mentioned before, its one of those things you don't look at on the walk through.
Bob
2013 Rockwood Ultra Lite 2703ws
2014 Toyota Tundra 5.7
gooiebob is offline   Reply With Quote
Old 04-28-2014, 08:49 PM   #10
I'll post this in the "ask the Wildcat" thread. uneven cushions would drive me crazy as well. Who would ever think this would be an issue?
2013 Wildcat 323QB
(2013 = 36)
(2012 = 42)
bed
