Old 09-09-2011, 01:25 AM   #1
cmcct's Avatar
Cracked Frame
"Holy Crap!" Those are the polite version of the words actually spoken by me while laying under my 2009 Roo 19 last Friday. I tow my trailer with a 1992 Ford F350 Crewcab, Diesel. Not the plush-est of rides, but it does very well at pulling the trailer, loaded with kids, dogs and supplies. Now, if any of you have driven the highways of British Columbia, you are familiar with the fact that they are little more than asphalt covered goat trails. Not exactly smooth, especially highway 3, our favorite.
Anyhoo, the roads, and my truck have worked together to actually crack the frame of my trailer. It is where the "A frame" goes through the front plate. The welds betweed the plate and the frame have broken, and the plate has also cracked from the hole where the propane hose bulkead fitting is, to the top of the plate where the bolt goes through the floor. As a matter of fact, the bolt is no longer there. I never tow with water in the tank, I keep as much weight as possible to the middle of the trailer, as far as I can tell, I'm doing everything that I'm supposed to be doing.
I went to the dealer, showed the service manager my pictures. He said basically what I said (see above). Trailer goes in for their evaluation Sept 17th, at which time they will take their own pictures and send them to Forest River. I had the extra year warranty, that's over. I have extended warranty, doesn't cover frame problems. Fortunately, where the A frame connects to the main frame rails, there are no cracks, so thats a small ray of sunshine. On a side note, I took a look at a 2011 Roo 19 while I was at the dealer, and the welds between the A frame and front plate are layed on WAY heavier than what was done on mine. So here's hoping Forest River has a little sympathy and offers to fix a frame that should not have broken after 2 years and 10 months of use.
ID:	7909   Click image for larger version
ID:	7910   Click image for larger version
Tow Vehicle: '92 F350, Crew Cab, 4X4, Cummins 5.9 24 Valve, 6spd.Driver:Clint, Navigator:Melanie, 1 dog (Great Pyrenees/Akbash cross) and now a cat too. Mission Statement: Just another adventure! Towed vehicle:2009 Roo 19 with lots of mods!
cmcct is offline   Reply With Quote
Old 09-09-2011, 07:15 AM   #2
Wanna Be Camper
SaskCampers's Avatar
Wow,
Good luck, hopefully FR or Lipert will step up and do you right. That is some poor welding there.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 09-09-2011, 08:03 AM   #3
Herk7769's Avatar
Be prepared for a "redirect" to your frame manufacturer.
HAM CALLSIGN - KC3FFW
Old 09-09-2011, 08:13 AM   #4
BigDTx's Avatar
yep looks like bad welds to me also.
BigDTx is offline   Reply With Quote
Old 09-09-2011, 08:28 AM   #5
jimh's Avatar
from what i can see, 2 and 3 are easy repairs.
the first picture is interesting. if i'm looking at it correctly, the crack is above the pipe.
the first picture reminds me of a static electricity fix they made on the chairs at work. a few weeks later, the chair broke where the hole was drilled.
all that to say, i wonder if they considered how the hole would weaken the frame.
sense u caught them before u had serious problems with the structure, the actual repair should be quick (red tape may take awhile).
the more i look at #3, the more i'd like to know why it cracked.
jimh is offline   Reply With Quote
Old 09-09-2011, 09:57 AM   #6
acadianbob's Avatar
X2. WHAT welds . . . ??
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 09-09-2011, 10:36 AM   #7
Villa Estate 392FLFB
The_Stuff's Avatar
hey, i wouldnt be surprised if it was the same idiot that only tack welded the wheels to the frame on my parents rig..
they got it welded to hold till they could get it to the dealer and make them fix it. if you are off warranty then i suggest find a good welding shop or buddy to fix it for ya and look over the rest of it.
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 09-10-2011, 02:39 PM   #8
cmcct's Avatar
Yup, we'll see what F.R. says they want to do after the dealer sends the photos to them. If it's not going to be covered, I'll take the trailer back and repair it myself. Actually, all I can do is have a sense of humor about it considering all of the weird things you find when the trailer is built. What does upset me though, is the fact that we most likely won't be able to go out for our "traditional" Thanksgiving last camp out of the year. As far as frame manufacturers warranty, if you have ever read their so called warranty policy, they could deny warranty even if you put a second battery on as it may be overloading a critical area. Who knows, hopefully F.R. will recognise the poor welding and help me out. Serves me right for actually towing my trailer on B.C. highways behind an older truck, right?
Old 11-12-2011, 06:35 AM   #9
great white's Avatar
Looks like the "broken" welds had very poor penetration. They look like surface beads mostly.
That's just a poor welder.
A hit with a grinder and a few passes with a welder will fix that in under and hour.
The crack in the cross rail?
Well, weld it if it can be welded. But if it goes from a hole to the hole for the LP line, it should be done traveling. The hole is essentially a stop drill, which is a common techinque for stopping cracks where the are. The only real concern it the amount the crack has covered on the beam. Looks to be about half the width, which compromises the strength. It also covers the bent corner on the beam, which gives it strength.
A good welding shop can tack on a doubler which will bring the strength back to the span. Just make sure you remove the LP line first, or the hot slag may melt and ruin it. That it should have no propane in it is self explanatory.
Good news is, should they deny your claim it should only cost around 100-200 bucks to have a local welding shop lay down a good quality weld for you. Then a shot of chassis black spray paint and you're better than (what you received as) new.
Good luck.
2011 Flagstaff Classic Superlight 831RLBSS "Atrium slide"
Husky Centerline Hitch
2016 Ford F-150 EcoBoost SuperCrew, Lariat Sport, Max Tow package
great white is offline   Reply With Quote
Old 11-12-2011, 03:46 PM   #10
Just thinking , you said bad roads were responsible maybe you could get you local goverment to step up..........I know I know .....thinking
Geaux is offline   Reply With Quote
