Old 05-13-2016, 08:29 AM   #1
Prime Member
Cranking the generator while plugged in.
I've been wondering if it's ok to to crank on the generator while it's plugged into my TT. I've got a Champion 3100W inverting generator with wireless start and would like to leave my TT plugged in and just remotely start and stop the generator.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 05-13-2016, 12:51 PM   #2
Quote from the owners manual:
Disconnect all electrical loads from the generator.
Never start or stop generator with electrical devices
plugged in or turned on.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 05-13-2016, 12:58 PM   #3
[QUOTE=timfromma;1193618]I've been wondering if it's ok to to crank on the generator while it's plugged into my TT. I've got a Champion 3100W inverting generator with wireless start and would like to leave my TT plugged in and just remotely start and stop the generator.[/QUOT
I think not. Class As have an automatic transfer switch that waits 15 seconds or so after the genny comes up to let it stabilize. Without that I would wait for the genny to get going and in regulation and then connect the load.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 05-14-2016, 09:58 PM   #4
I have an auto transfer switch in my camper that delays generator load by about 30 seconds to give it time to stabilize. A very easy and cheap way to allow you to start the generator with everything plugged in.
Skyliner is online now   Reply With Quote
Old 05-15-2016, 11:28 AM   #5
You could just turn off the main breaker in the camper while the generator starts and stabilizes. Then flip it back on.
RandyLee is offline   Reply With Quote
Old 05-15-2016, 11:36 AM   #6
NMWildcat's Avatar
If you have an inverter genny (like yours) you can probably get away with it. A contractor style... definitely taking a chance as the power fluctuates during startup/shutdown.
I try to to remember to flip the main breaker when I start the generator, sometimes I do, sometimes I don't. Haven't had any problems over 10 years. Usually when I start the generator the only thing on is the converter and a few lights.
Scott and Liz - Southern NM
Old 05-15-2016, 03:20 PM   #7
Flovern
Not all class As have an automatic transfer switch. Mine doesn't.
2011 Coachmen Sportscoach
flovern is offline   Reply With Quote
Old 05-22-2016, 06:54 PM   #8
I have added an automatic transfer switch to my 2017 coachmen for that reason
Dan2 is offline   Reply With Quote
Old 05-22-2016, 07:39 PM   #9
W5CI's Avatar
If your Coachman has an on board generator it has a transfer switch
Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2017 Days Camping 77
2018 Days Camping 3
W5CI is offline   Reply With Quote
Old 05-22-2016, 08:08 PM   #10
Flovern
Transfer switch
Again, not all Coachmen have a transfer switch. I have to manually plug my shore power cable into the generator output plug to use generator power.
generator
